×Hello
Is there a way we can run 2 different builds running simultaneously on one agent server. Presently we see the Builds waiting in the queue for other build to complete. If we have parallel build then we need not wait for first build to complete and the second build will be picked up parallely.
Cheers
Sandeep
Hello Sandeep,
You can't run several builds in parallel on same agent, but you can run them in parallel if you have more that one agent connected to Bamboo server
Thanks Alexey , I could only see Concurrent build option in settings and never saw Parallel Build option. This means i need to configure the Build Plan Requirement to have 2 agents enabled to run the job and it will run in parallel if one of the agent is busy. Cheers Sandeep
