Issues Connecting Bamboo to bitbucket server
Michael Castro April 16, 2019
I am trying to connect my bamboo server to the bitbucket server, I thought to install the remote agent would make it easier.  I got the installer on the server and it does not install? I changed the system variable to set the JAVA_HOME. I run the command that is given on the bamboo site. The command will run but it says it fails 3 times and the wrapper has stopped. this is the error I get. I replaced certain things with just zeros.
INFO | jvm 4 | 2019/04/16 12:41:10 | 2019-04-16 12:41:10,418 INFO [WrapperSimpleAppMain] [AgentBootstrap] Agent bootstrap using endpoint: http://000.000.000.00:8085/agentserver/agentServer/
INFO | jvm 4 | 2019/04/16 12:41:10 | 2019-04-16 12:41:10,449 INFO [WrapperSimpleAppMain] [RemoteAgentHomeLocatorForBootstrap] Using agent home located at [C:\Users\a_mcastro\bamboo-agent-home]
INFO | jvm 4 | 2019/04/16 12:41:10 | 2019-04-16 12:41:10,449 INFO [WrapperSimpleAppMain] [AgentUuidInitializer] Found agent UUID '5be5ead8-a301-4c4d-aa80-9070eebd580c' in temporary UUID file 'C:\Users\a_mcastro\bamboo-agent-home\uuid-temp.properties'
INFO | jvm 4 | 2019/04/16 12:41:10 | 2019-04-16 12:41:10,465 INFO [WrapperSimpleAppMain] [AgentContext] Requesting fingerprint, url: http://000.000.000.00:8085/agentserver/agentServer/GetFingerprint.action?hostName=BitBucket.aff.local&version=3&agentUuid=5be5ead8-a301-4c4d-aa80-9070eebd580c&securityToken=000000000000000000000000000000000000
INFO | jvm 4 | 2019/04/16 12:41:10 | 2019-04-16 12:41:10,465 INFO [WrapperSimpleAppMain] [RemoteAgentHttpClientFactory] Creating a new HTTP client...
INFO | jvm 4 | 2019/04/16 12:41:11 | 2019-04-16 12:41:10,918 INFO [WrapperSimpleAppMain] [AgentContext] Authenticating against Bamboo server at http://000.000.000.00:8085/agentserver/agentServer/
INFO | jvm 4 | 2019/04/16 12:41:11 | 2019-04-16 12:41:10,996 ERROR [WrapperSimpleAppMain] [AgentContext] An error has occurred when requesting fingerprint: HTTP/1.1 404
INFO | jvm 4 | 2019/04/16 12:41:11 | Exiting due to fatal exception.
INFO | jvm 4 | 2019/04/16 12:41:11 | com.atlassian.bamboo.agent.bootstrap.RemoteAgentHttpException: Response: [HTTP/1.1 404 ] received after fingerprint request.
INFO | jvm 4 | 2019/04/16 12:41:11 | at com.atlassian.bamboo.agent.bootstrap.AgentContext.initFingerprint(AgentContext.java:156)
INFO | jvm 4 | 2019/04/16 12:41:11 | at com.atlassian.bamboo.agent.bootstrap.AgentContext.initServerSession(AgentContext.java:101)
INFO | jvm 4 | 2019/04/16 12:41:11 | at com.atlassian.bamboo.agent.bootstrap.AgentContext.run(AgentContext.java:88)
INFO | jvm 4 | 2019/04/16 12:41:11 | at com.atlassian.bamboo.agent.bootstrap.AgentBootstrap.run(AgentBootstrap.java:111)
INFO | jvm 4 | 2019/04/16 12:41:11 | at com.atlassian.bamboo.agent.bootstrap.AgentBootstrap.main(AgentBootstrap.java:50)
INFO | jvm 4 | 2019/04/16 12:41:11 | at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
INFO | jvm 4 | 2019/04/16 12:41:11 | at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
INFO | jvm 4 | 2019/04/16 12:41:11 | at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
INFO | jvm 4 | 2019/04/16 12:41:11 | at java.lang.reflect.Method.invoke(Unknown Source)
INFO | jvm 4 | 2019/04/16 12:41:11 | at org.tanukisoftware.wrapper.WrapperSimpleApp.run(WrapperSimpleApp.java:240)
INFO | jvm 4 | 2019/04/16 12:41:11 | at java.lang.Thread.run(Unknown Source)
INFO | jvm 4 | 2019/04/16 12:41:11 | 2019-04-16 12:41:10,996 FATAL [WrapperSimpleAppMain] [AgentBootstrap] Exiting due to fatal exception.
ERROR | wrapper | 2019/04/16 12:41:11 | JVM exited while starting the application.
STATUS | wrapper | 2019/04/16 12:41:15 | Launching a JVM...
INFO | jvm 5 | 2019/04/16 12:41:15 | Wrapper (Version 3.2.3-atlassian-1) http://wrapper.tanukisoftware.org
INFO | jvm 5 | 2019/04/16 12:41:15 | Copyright 1999-2006 Tanuki Software, Inc. All Rights Reserved.
INFO | jvm 5 | 2019/04/16 12:41:16 | 2019-04-16 12:41:15,938 INFO [WrapperSimpleAppMain] [AgentBootstrap] Starting Agent Bootstrap using Java 1.8.0_201 from Oracle Corporation. Default charset: windows-1252, file name encoding: Cp1252
INFO | jvm 5 | 2019/04/16 12:41:16 | 2019-04-16 12:41:15,938 INFO [WrapperSimpleAppMain] [AgentBootstrap] Agent bootstrap using endpoint: http://000.000.000.00:8085/agentserver/agentServer/
INFO | jvm 5 | 2019/04/16 12:41:16 | 2019-04-16 12:41:15,938 INFO [WrapperSimpleAppMain] [RemoteAgentHomeLocatorForBootstrap] Using agent home located at [C:\Users\a_mcastro\bamboo-agent-home]
INFO | jvm 5 | 2019/04/16 12:41:16 | 2019-04-16 12:41:15,938 INFO [WrapperSimpleAppMain] [AgentUuidInitializer] Found agent UUID '5be5ead8-a301-4c4d-aa80-9070eebd580c' in temporary UUID file 'C:\Users\a_mcastro\bamboo-agent-home\uuid-temp.properties'
INFO | jvm 5 | 2019/04/16 12:41:16 | 2019-04-16 12:41:15,953 INFO [WrapperSimpleAppMain] [AgentContext] Requesting fingerprint, url: http://000.000.000.00:8085/agentserver/agentServer/GetFingerprint.action?hostName=BitBucket.aff.local&version=3&agentUuid=5be5ead8-a301-4c4d-aa80-9070eebd580c&securityToken=000000000000000000000000000000000000
INFO | jvm 5 | 2019/04/16 12:41:16 | 2019-04-16 12:41:15,953 INFO [WrapperSimpleAppMain] [RemoteAgentHttpClientFactory] Creating a new HTTP client...
INFO | jvm 5 | 2019/04/16 12:41:16 | 2019-04-16 12:41:16,406 INFO [WrapperSimpleAppMain] [AgentContext] Authenticating against Bamboo server at http://000.000.000.00:8085/agentserver/agentServer/
INFO | jvm 5 | 2019/04/16 12:41:16 | 2019-04-16 12:41:16,469 ERROR [WrapperSimpleAppMain] [AgentContext] An error has occurred when requesting fingerprint: HTTP/1.1 404
INFO | jvm 5 | 2019/04/16 12:41:16 | Exiting due to fatal exception.
INFO | jvm 5 | 2019/04/16 12:41:16 | com.atlassian.bamboo.agent.bootstrap.RemoteAgentHttpException: Response: [HTTP/1.1 404 ] received after fingerprint request.
INFO | jvm 5 | 2019/04/16 12:41:16 | at com.atlassian.bamboo.agent.bootstrap.AgentContext.initFingerprint(AgentContext.java:156)
INFO | jvm 5 | 2019/04/16 12:41:16 | at com.atlassian.bamboo.agent.bootstrap.AgentContext.initServerSession(AgentContext.java:101)
INFO | jvm 5 | 2019/04/16 12:41:16 | at com.atlassian.bamboo.agent.bootstrap.AgentContext.run(AgentContext.java:88)
INFO | jvm 5 | 2019/04/16 12:41:16 | at com.atlassian.bamboo.agent.bootstrap.AgentBootstrap.run(AgentBootstrap.java:111)
INFO | jvm 5 | 2019/04/16 12:41:16 | at com.atlassian.bamboo.agent.bootstrap.AgentBootstrap.main(AgentBootstrap.java:50)
INFO | jvm 5 | 2019/04/16 12:41:16 | at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
INFO | jvm 5 | 2019/04/16 12:41:16 | at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
INFO | jvm 5 | 2019/04/16 12:41:16 | at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
INFO | jvm 5 | 2019/04/16 12:41:16 | at java.lang.reflect.Method.invoke(Unknown Source)
INFO | jvm 5 | 2019/04/16 12:41:16 | at org.tanukisoftware.wrapper.WrapperSimpleApp.run(WrapperSimpleApp.java:240)
INFO | jvm 5 | 2019/04/16 12:41:16 | at java.lang.Thread.run(Unknown Source)
INFO | jvm 5 | 2019/04/16 12:41:16 | 2019-04-16 12:41:16,469 FATAL [WrapperSimpleAppMain] [AgentBootstrap] Exiting due to fatal exception.
INFO | jvm 5 | 2019/04/16 12:41:16 | at com.atlassian.bamboo.agent.bootstrap.AgentBootstrap.run(AgentBootstrap.java:111)Do I need to set an Inbound firewall rule for my bamboo server to allow bitbucket to connect to it? I also tried to use the install without the wrapper and I get this error.
2019-04-16 12:19:00,539 INFO [main] [AgentBootstrap] Starting Agent Bootstrap using Java 1.8.0_201 from Oracle Corporation. Default charset: windows-1252, file name encoding: Cp1252
2019-04-16 12:19:00,539 ERROR [main] [AgentBootstrap] Incorrect command line syntax. Maximum two arguments allowed. 3 arguments were passed: http://000.000.000.00:8085/age
Kurt Klinner
April 16, 2019
@Michael Castro
Got it, seems like the agent has issues while authenticating against the bamboo server.
the context seem to be added twice  /agentserver/agentServer/
How did you install the agent? The 404 error is also described at
https://confluence.atlassian.com/bamkb/remote-agent-fails-to-start-up-http-status-code-404-received-in-response-to-fingerprint-request-300814507.html
and is related to the wrong bamboo server url
Cheers
Kurt
Honestly, I don't think it is installed. I click on the jira download and it does not run. it opens and closes.
Kurt Klinner
April 16, 2019
@Michael Castro
i did not get that, "I click on the jira download and it does not run" what exactly do you mean.?
Michael Castro April 17, 2019
When you click this to download the jar file and I move it to the server. When I double click on it. there is no install action. I also try to unwrap it and it fails..
Kurt Klinner
April 17, 2019
@Michael Castro
Please check at the page where you download the agent
there is the command stated that you need to run
see also
https://confluence.atlassian.com/bamboo/bamboo-remote-agent-installation-guide-289276832.html
Michael Castro April 18, 2019
So I ran the command and it fails. the wrapper exists.
Kurt Klinner
April 20, 2019
@Michael Castro
What error / message did you get when the wrapper exited?
Michael Castro April 24, 2019 edited
Now this is not a need, but I appreciate the help
Kurt Klinner
April 16, 2019
I changed it just for this, so I wasn't putting my servers IP out there. I also did it for the security token
