×In the Error Log in bamboo the message in looking like that:
expecting [????], actual was [??????‚]
The Jnuit results.xml is valid and in UTF-8!
This is what i wanna see:
expecting [中国河北省邢台市南宫市], actual was [中国河北省邢台市]
In bamboo i also tryed to change the wrapper.conf file with "wrapper.java.additional.X=-Dfile.encoding=utf-8" without a good result..
Is this a JUnit Parser Problem i think..
I have the same kind of issue with out Bamboo installation, any other clue on this issue ?
Hi Mad,
Can you check from the system informatio in Bamboo to ensure that the file encoding has taken effect? Also check that your database is using the utf8 encoding sheme
Sultan
