×hi
i have a programm which can not generete a junit Report but its doing a dailyRegression Test in bamboo.
what i have done:
in bamboo add add this in "JUnit Parser Configuration"
/opt/bamboo/bamboo-agent-home/xml-data/build-dir/SRCHCI-TEST-JOB1
after my HTML Report ist done i created this report.XML
<?xml version='1.0'?> <testsuites> <testsuite name='$testname' tests='555' failures='0' errors='0' time='0.022' package='IRFANsystemtests' id='1'> </testsuite> </testsuites>"
The probel is bamboo can not find the XML
Could not find test result reports in the /opt/bamboo/bamboo-agent-home/xml-data/build-dir/SRCHCI-SRCHCI-TEST-JOB1-JOB1 directory.
I just wann see in my bamboo plan how many were passed and how man daild in the startPage..
"like: 1 of 7 failed"
any ideas?
Hi there,
Please try the workarounds from this tracked bug and let me know if that helps (using 'touch' and 'sleep' commands in a preceeding Script task).
Armen
