Limiting disk space for Bamboo build plans
emddudley
Is there any way to put a limit on the amount of disk space a build plan is allowed to use? How can I prevent a build plan from using too much disk space?
Our Bamboo agents are used by lots of independent teams, and sometimes one team makes a mistake and uses up all the available disk space. Either they check out too much software from source control or their build script generates too many files.
Timothy
May 6, 2014
Unfortunately, Bamboo does not have that functionality. You can always create bash script on the server that does the validation and then run that script using a script task.
Or you can limit it on the OS level.
