NVM command not found from bamboo plan but works in local
Mahesh
June 10, 2024 edited
Hi There,
I have installed NVM in my ubuntu build agent. I am able to use nvm and node commands in my local.
But when I run nvm or node commands from bamboo plan, Plan fails with error as node command not found. Same for nvm also.
When I use full path for node it works.
/opt/bamboo-agent-home/.nvm/versions/node/v12.21.0/bin/node -v
But nvm is not working. please suggest.
Error :
/opt/bamboo-agent-home/temp/TEST-SCR-LT-71-ScriptBuildTask-47945519012.sh: 9: /opt/bamboo-agent-home/temp/TEST-SCR-LT-71-ScriptBuildTask-47945519012.sh: nvm: not found
Shashank Kumar
June 10, 2024
Hello Mahesh,
Welcome to Atlassian community
You can try the below 2 things.
1. Install nvm in a location using the user which is running the Bamboo agent and is location is accesible to the bamboo user which is running the agent.
2. After Installing check if nvm is getting listed in the capabilities of the agent, if not try restarting the agent and check.
3. If that does not work too, try defining the capabilities manually
Post all the above steps try a simple script task with command nvm --version and let me know the results.
Shashank Kumar
Mahesh
Hi @Shashank Kumar ,
Thanks for the reply.
I installed nvm using command "curl -o- https://raw.githubusercontent.com/nvm-sh/nvm/v0.35.3/install.sh | bash"
It is not listed in capabilities. After restart also same it is not listed.
Tried to add nvm path in capabilities but i am not able to find the nvm executable. Which one to be added as executable ???
Shashank Kumar
June 11, 2024
Hello Mahesh,
nvm is a shell function and not a shell executable file so you'll not be able to add it as a executable.
There are few options which you can work with.
1. Add the below entry in .profile file in your linux box.
export NVM_DIR="$HOME/.nvm"
[ -s "$NVM_DIR/nvm.sh" ] && \. "$NVM_DIR/nvm.sh"
2. Or add it in the script task ( like attached )
When you run this script task, you should be able to see the results.
Shashank Kumar
**please don't forget to Accept the answer if your query was answered**
Like • Steffen Opel _Utoolity_ likes this
Mahesh
By adding this I can see nvm version, When I use node command again it says command not found. In local can see node version. and it can be managed by only "nvm use --delete-prefix v16.20.2"  simple nvm use 16 command is not working.
It throws error as below.
bam:~$ nvm use 16
nvm is not compatible with the npm config "prefix" option: currently set to "/data/home/bambooagent/.nvm/versions/node/v16.20.2"
Run `nvm use --delete-prefix v16.20.2` to unset it.
bam:~$
node command error : 848876677.sh: node: not found
Mahesh
@Shashank Kumar
Any suggestions here
