Newly created Task Type not displayed
Seetharam
September 15, 2020
Hi All,
I am creating a plugin to create new task type. This is just a basic task which logs Hello World in the Build Logger. I have created the class by implementing the TaskType interface and added the necessary <tastype> tags in atlassian-plugins. xml as well. But i cant see my newly created task in Bamboo.
atlassian-plugin.xml :
<atlassian-plugin key="${atlassian.plugin.key}" name="${project.name}" plugins-version="2">
<plugin-info>
<description>${project.description}</description>
<version>${project.version}</version>
<vendor name="${project.organization.name}" url="${project.organization.url}" />
<param name="plugin-icon">images/pluginIcon.png</param>
<param name="plugin-logo">images/pluginLogo.png</param>
</plugin-info>
<!-- add our i18n resource -->
<resource type="i18n" name="i18n" location="secondPlugin"/>
<!-- add our web resources -->
<web-resource key="secondPlugin-resources" name="secondPlugin Web Resources">
<dependency>com.atlassian.auiplugin:ajs</dependency>
<resource type="download" name="secondPlugin.css" location="/css/secondPlugin.css"/>
<resource type="download" name="secondPlugin.js" location="/js/secondPlugin.js"/>
<resource type="download" name="images/" location="/images"/>
<context>secondPlugin</context>
</web-resource>
<taskType key="task.newTask" name="My First New Task" class="com.atlassian.tutorial.secondPlugin.MyFirstTask">
<description>A task that prints 'Hello, World!'</description>
</taskType>
</atlassian-plugin>
MyFirstTask.java
package com.atlassian.tutorial.secondPlugin;
import com.atlassian.bamboo.build.logger.BuildLogger;
import com.atlassian.bamboo.task.TaskContext;
import com.atlassian.bamboo.task.TaskException;
import com.atlassian.bamboo.task.TaskResult;
import com.atlassian.bamboo.task.TaskResultBuilder;
import com.atlassian.bamboo.task.TaskType;
public class MyFirstTask implements TaskType
    @Override
    public TaskResult execute(final TaskContext taskContext) throws TaskException
        final BuildLogger buildLogger = taskContext.getBuildLogger();
        buildLogger.addBuildLogEntry("Hello, World!");
        return TaskResultBuilder.newBuilder(taskContext).success().build();
Richard White [TechTime]
Hi Seetharam,
You might have more luck finding help in:
Atlassian Developer Community - Bamboo
Your plugin looks more or less correct to me, so might be worth investigating if your plugin is enabled correctly in Manage Apps?
