Not all artifacts listed for a plan branch
Zuber Khursiwala
Hi
In my main build plan, I've got a list of artifacts with about 20 things in it. However the list is much smaller when I view the artifacts for a plan branch.
I can see the artifact has been created - I can even see it on the disk. But it isn't showing up on the screen.
In the logs, I see:
simple	21-Jun-2016 14:47:44	Publishing an artifact: Back End Code (ora*.dll excluded)
error	21-Jun-2016 14:47:44	Unable to publish artifact [Back End Code (ora*.dll excluded)]:
simple	21-Jun-2016 14:47:44	The artifact hasn't been successfully published after 0s
Any ideas why it can't publish the artifact?
Mark de Bont
June 21, 2016
You're right, see https://jira.atlassian.com/browse/BAM-10740 , waiting for bug-fix
Zuber Khursiwala
Ah, I'll answer my own question. It didn't like the asterisk (*) in the name. Removed that and it works, the artifact appears in the list.
I guess there are a few characters that you shouldn't use in the name, but the front end lets you enter.
Alexey Chystoprudov
July 5, 2016
