I'm trying to build a nightly-build-plan for Bamboo with the help of the CLI. Is it possible, to pipe the output of the queued builds to stdout, so I can see everything that happened in the log of the nightly-build-plan? Currently my log looks something like this:
25-Apr-2014 14:51:54 Build A-A submitted. Waiting ... 25-Apr-2014 14:52:04 Build A-A-13 completed. 25-Apr-2014 14:52:05 Build A-B submitted. Waiting ... 25-Apr-2014 14:52:46 Build A-B-14 completed. 25-Apr-2014 14:52:47 Build A-C submitted. Waiting ... 25-Apr-2014 14:54:08 Build A-C-6 completed. 25-Apr-2014 14:54:10 Build A-D submitted. Waiting ... 25-Apr-2014 14:55:11 Build A-D-123 completed.
Not that I am aware of. Just to be clear, I will state your request in another way. You want the log of another build (once it is complete) to be copied into the current build log.
Not exactly. What I want is, to see the output of a build when I run the build via the CLI. It doesn't really matter if I start the build through another build or from the console.
So, if I do a queueBuild with wait, provide an option to retrieve the build log. Yes, I think that might be possible. And if it is run as part of a build, the log would get included, however, it would have both the log timestamp from the current build and the log timestamp from the build that was queued for each entry.
Can you please open a improvement request for this?
