Powershell Script Class
CarlAtCdgems May 21, 2020
Bamboo version 6.10.4
Powershell version 5.1
I have a Bamboo Task setup as Script Interpreter - Windows PowerShell, Script Location - In Line.
Within the in-line powershell script, I set a few variables, then call .\Test.ps1
After changes are made to the Test.ps1, it is saved, highlighted and run so PS has the updated version in memory.  I need Bamboo to run the new version of Test.ps1 but it is running an old version.  How can I force Bamboo to re-read/re-cache the powershell script?
Carl
Edwin Kyalangalilwa
May 26, 2020
Hi @CarlAtCdgems ,
Is the script being sourced from a code repository? If so, then you may want to clean the build directory.
