Sign up Log in
Pre-Post Build Command Runner plugin curl fail
Ian Vaughan May 16, 2015
I have installed https://marketplace.atlassian.com/plugins/com.sysbliss.bamboo.plugins.prepost-build-command
I added a command "curl ..."
But I get a error in the log output :
simple 16-May-2015 22:48:00 [BuildCommandRunner] running command: curl ....
error 16-May-2015 22:48:00 Unable to find executable at curl. Will try to run it anyway.
So I added an Executable via /admin/agent/viewBuilders.action
Named "curl", path "curl".
That didn't work, so I tried the linux path "/usr/bin/curl", that didn't work either.
Is the problem with the addon not finding the exec, or the exec?
Krystian Brazulewicz
May 17, 2015
Use the full path to curl in prepost-build-command plugin.
Ian Vaughan May 18, 2015
Cheers, I actually worked it out by process of elimination, but still a valid post I think in case others run into this problem.
Kazi Rizwan September 14, 2020
@Krystian Brazulewicz  can you explain in detail where the add the full path ?
Victor Debone
September 17, 2020
Hello @Kazi Rizwan ,
The full path is required on the field "Commands" in the plugin:
In the case of curl, you would not insert `curl` but the full path `/usr/bin/curl`
I hope that helped :)
Like Steffen Opel _Utoolity_ likes this
Alexey Chystoprudov
May 16, 2015
Hello Ian,
Please check that curl executable is available at Bamboo server or agent machine via command line.
Create Script task with curl command to identify if issue is at Bamboo or plugin side.
