I have two plans that use a shared resource, and which can't run simultaneously, even though there may be agents available to run them. Is there a way I can do this in Bamboo?
I implemented a simple plugin to solve this problem a while back and have just gotten approval to open source it. Source and documentation can be found here: https://github.com/ampedandwired/bamboo-mutex-plugin.
This would still be better implemented within Bamboo core I think, but this plugin should do the job until BAM-2423 is implemented.
I can think of a workaround. Configure both the plans to run on the same remote agent. Then only one plan can run at a time.
In order to restrict the plan to run on the same agent, add a custom capability to the agent with a unique key and then configure the plans to run only when the custom capability is present!
Would the following Feature Request work? https://jira.atlassian.com/browse/BAM-11447
Thanks Jobin,
Using capabilities to run both plans on a single agent is not going to get the result I want, unfortunately. Each of the plans in question has numerous jobs that I *want* to be run in parallel across many agents (they are long running acceptance test jobs). It's just that I don't want jobs from the different plans intermingling.
I may look into writing a custom plugin for this if no other options.
Thats great. If you have any questions about plugin development, post them on Answers :)
AFAIK sequencing is achieved based on agent availability. If you have multiple agents which can do the same work, I guess it will get started in parallel. Is it not possible that you have a single agent for this work so that it gets done in parallel? Use a custom capablity if needed so that the job looks for this specific agent for its work.
Okie I understand. Will it be possible to pull out this particular job alone and make a new plan with this single agent? And trigger this new plan when the original one ends. http://confluence.atlassian.com/display/BAMBOO40/Setting+up+plan+build+dependencies
Heads up! Opsgenie's features are moving to Jira Service Management and Compass. Planning your migration? Join our dedicated group for resources and tips from Atlassian and the Community to ensure a smooth transition.
Check it out ↗
