Problem with sudo cp an artifact to another location: No such file
Sören Kornetzki September 16, 2014
I would like to sudo cp the downloaded artifact into the final deployment location. Unfortunately cp complains that it cannot find the file but looks in the very same working directory. Due to a debugging session I also insert a ls-debug task between artifact download and sudo cp. The file is there. Can anybody help me to solve this?
Snippets from the build log:
Preparing to download plan result TSDE-TSDE-1 artifact: Shared artifact: [TSDE Distribution Artifact], pattern: [Tomatenstau-de-*.tar.gz]
Artifact [TSDE Distribution Artifact] downloaded successfully in 0s to working directory
Finished task 'Download release contents' with result: Success
Starting task 'DEBUG' of type 'com.atlassian.bamboo.plugins.scripttask:task.builder.script'
bamboo_build_working_directory=/srv/atlassian/data/bamboo/xml-data/build-dir/819202-950274
-rw-r--r-- 1 atlassian atlassian 9.1M Sep 17 10:53 Tomatenstau-de-0.001.tar.gz
Finished task 'DEBUG' with result: Success
Starting task 'Copy distribution artifact to the deplyment stage' of type 'com.atlassian.bamboo.plugins.scripttask:task.builder.command'
cp: cannot stat `Tomatenstau-de-*.tar.gz': No such file or directory
Failing task since return code of [/usr/bin/sudo cp -f Tomatenstau-de-*.tar.gz /home/meik/tomatenstau.de/deploy-me/] was 1 while expected 0
Finished task 'Copy distribution artifact to the deplyment stage' with result: Failed
Krystian Brazulewicz
September 16, 2014
Your Copy distribution artifact to the deplyment stage task is a Command task. Arguments to Command task are not shell expanded, it means that you are actually executing a command that you'd write in the shell like this:
/usr/bin/sudo cp -f 'Tomatenstau-de-*.tar.gz' '/home/meik/tomatenstau.de/deploy-me/'
and of course you don't have a file named Tomatenstau-de-*.tar.gz
I'd suggest using script task for the other task as well.
Sören Kornetzki September 17, 2014
I use the script task an it works. Please let the PM notice that this information would have a major value when mention it within the script task box.
September 18, 2014
Thx for the suggestion, I passed it to our tech writer.
Przemek Bruski
September 16, 2014
that ls-debug - are you running it through sudo?
No. Do you think sudo is changing working directory? I will try it too.
{{sudo ls -ahl}} will produce the same output as the normal {{ls -ahl}} does.
