Problems with MSBuild
Norbert
August 27, 2013
Hello Guys
My C++ projekt won't compile on my Bamboo testinstallation.
I'm using the msbuildtask with VS 2012. If I run it from a commandline it works fine
If i run it via bamboo it failes with the error
build	26-Aug-2013 18:07:12	C:\Program Files (x86)\MSBuild\Microsoft.Cpp\v4.0\V110\Microsoft.CppCommon.targets(347,5): error MSB4018: The "CL" task failed unexpectedly. [C:\data\bamboo-home\xml-data\build-dir\MYProject-IMB-JOB1\icos\common\common.vcxproj]
build	26-Aug-2013 18:07:12	C:\Program Files (x86)\MSBuild\Microsoft.Cpp\v4.0\V110\Microsoft.CppCommon.targets(347,5): error MSB4018: System.TypeInitializationException: The type initializer for 'Microsoft.Build.Utilities.FileTracker' threw an exception. ---> System.IO.DirectoryNotFoundException: Das System kann den angegebenen Pfad nicht finden. (Exception from HRESULT: 0x80070003) [C:\data\bamboo-home\xml-data\build-dir\MyProject-IMB-JOB1\icos\common\common.vcxproj]
What I'm doing wrong?
I also created a batch file and run it as SYSTEM User. This also works fine. so it shouldn't be a problem with User rights.
Norbert
August 27, 2013
Hi
I found the problem. MSBUILD cannot use the default temp directory of Windows 7
Changing the MSBUILD task to an inline task
set temp=c:\temp
set tmp=c:\temp
C:\Windows\Microsoft.NET\Framework\v4.0.30319\MSBuild.exe /t:rebuild /p:Configuration=Release /p:Platform=Win32 /m /fileLogger cxxx2012.sln
fixes the problem. If I remove the "set temp" commandos it fails again with the same error messages
Jason Monsorno
August 27, 2013
Have you tried running msbuild on the exact same checkout Bamboo is using? Run MSBuild on the files in C:\data\bamboo-home\xml-data\build-dir\MyProject-IMB-JOB1\. Your personal local copy may have an extra file that wasn't included in your Source Control.
Julian Riedinger _Decadis AG_
August 27, 2013
I'm not shure but the atlassian products have a problem with spaces in the path. Maybe this causes your exception. The MABuild is installt to "C:\Program Files (x86)\"...
Hope that helps
