Is their a way to have quarantined tests for one build plan auto populated to another? We have essentially two Main build plans. One is used for offshore work that gets merged back to the primary daily. At any given time we have 10-20 quarantined tests coming and going that we would like to be mimicked in the secondary project build plan without having to manually keep them in sync.
Hi @tdzarnes
Bamboo does not have an out-of-the-box feature for this.
I totally get your scenario, thank you for explaining it. I'll share what I have and hope that this allows you to move forward.
Bamboo has a rest API to add tests to quarantine, this is the one:
curl -u <USER>:<PASSWORD> \
-H 'Content-Type: application/json' -d{} \
-X POST http://<BAMBOO-URL>/rest/api/latest/plan/COM-TO/test/<TEST-CASE-ID>/quarantine
You will notice that you will need to get the <TEST-CASE-ID> for each one of the tests that you want to put in quarantine. There are two problems here:
In order to workaround this I was able to build a query that will show the equivalence of each test considering the test class and test name in both plans.
This is the one:
⚠️It was designed for Postgres DB. In case your DB is different, please update it accordingly.
WITH plan1_tests AS (SELECT * FROM build b JOIN test_class tcl ON tcl.plan_id=b.build_id JOIN test_case tc ON tc.test_class_id=tcl.test_class_id WHERE b.full_key like 'PROJ-PLAN1%'), plan2_tests AS (SELECT * FROM build b JOIN test_class tcl ON tcl.plan_id=b.build_id JOIN test_case tc ON tc.test_class_id=tcl.test_class_id WHERE b.full_key like 'PROJ-PLAN2%') SELECT p1.test_class_name, p1.test_case_name, p1.full_key AS p1_full_key, p1.test_case_id AS p1_test_case_id, CASE WHEN p1.quarantine_date IS NOT NULL THEN '---YES---' ELSE '---NO---' END AS p1_quarantined, p2.full_key AS p2_full_key, p2.test_case_id AS p2_test_case_id, CASE WHEN p2.quarantine_date IS NOT NULL THEN '---YES---' ELSE '---NO---' END AS p2_quarantined FROM plan1_tests p1 JOIN plan2_tests p2 ON (p1.test_class_name=p2.test_class_name AND p1.test_case_name=p2.test_case_name) WHERE p1.quarantine_date IS NOT NULL OR p2.quarantine_date IS NOT NULL
The query should show you only the tests that are quarantined in any of those plans. It could be in the first one, the second one or both. With some programming skills, you should be able to make a script to get these details from the Bamboo DB and run a couple of REST APIs to adjust one plan based on the other one.
I hope it helps.
