Required Dropdown instead of textbox - Run customized - Override variable
Madhu May 9, 2023
Hi Team,
Can you please help me how to get dropdown when i click on run customized-->override variable-->instead of text box need drop down.
Can you please help me on this.
Thanks in Advance!!
Madhu Balineni
Eduardo Alvarenga
May 9, 2023
Hello @Madhu
Can you please tell us what is your Bamboo version?
Eduardo Alvarenga
Atlassian Support APAC
Madhu May 11, 2023
Hi Eduardo,
Please find the below bamboo version,
Continuous integration powered by Atlassian Bamboo version 8.1.10 build 80118 - 04 Nov 22
Thank you!!
Eduardo Alvarenga
May 11, 2023
Hello @Madhu,
Bamboo 8.1 already has a dropdown list box when using the "Run Customized" dialogue:
If you are looking for a dropdown list assigned to the value of the variable; that's not supported.
Can you please elaborate a bit more?
More information:
Eduardo Alvarenga
--please don't forget to Accept the answer if the reply is helpful--
Like Steffen Opel _Utoolity_ likes this
Madhu May 12, 2023
i am looking for drop down for value not for property.
Thanks!!
