Hello all,
I try to configure a Task to run SQL scripts (located in git repository).
I try with Powershell / sqlcmd, but not sure this is possible / manageable ?
Starting my test with
Invoke-Sqlcmd -Username xxx -Password yyy -InputFile "gitrepo/folder/script.sql" -ServerInstance "YYYY"
failed and return:
Failing task since return code of [powershell -NonInteractive -ExecutionPolicy bypass -Command /bin/sh /opt/bamboo-agent-home/temp/xxx.ps1] was -1 while expected 0
Moreover, my needs would to execute only updated scripts.
Is there a way to do that ?
THanks in advance.
regards,
changing operating systems on plan task solved the issue
