Running python Scripts on Bamboo
Yaswanth Attuluri May 5, 2022
How can i run python scripts on Bamboo. Can i run an inline script task or should i have to run the script through an external file.
Raj-Nirosh.Borra
November 21, 2022
Create ansible script to run customized build on all develop branches for all mulesoft bamboo plans.
can anyone pls help me about this..???
Eduardo Alvarenga
May 6, 2022
Hello @Yaswanth Attuluri
Please check the Script task documentation for more information.
Eduardo Alvarenga
Atlassian Support APAC
Yaswanth Attuluri May 6, 2022
Thanks for the information. If possible, Could you please elaborate as i am new to bamboo:
How can I use external files ?
How to add #!/usr/bin/python ?
in the script task, how can i get the python packages installed with simple example.
Eduardo Alvarenga
May 5, 2022
You can run scripts either inline by pasting the script on the Script task UI or you can use an external file as you wish.
Make sure to add the traditional #!/usr/bin/python shebang (or equivalent path) to each script.
Eduardo Alvarenga
