Running python3 and pip commands in Bamboo using Remote Agent
Chong Jing Hong May 25, 2022 edited
I have a remote agent dedicated to my Bamboo Build Plan. I want to run a python script, which requires pip installation of libraries before the script can execute. I've already added the pip and python executables into the remote agent's capabilities, as such:
system.builder.python.Python38=C:\\Users\\...\\AppData\\Local\\Programs\\Python\\Python38\\python.exe
system.builder.py.pip=C:\\Users\\...\\AppData\\Local\\Programs\\Python\\Python38\\Lib\\site-packages\\pip
Broken Links:
  tasks:
  - checkout:
      force-clean-build: 'false'
      description: Checkout Default Repository
  - script:
      interpreter: BINSH_OR_CMDEXE
      scripts:
        - pip install BeautifulSoup4
        - pip install lxml
        - pip install requests
        - python3 broken_links.py
  requirements:
    - Python38
    - pip
But, when I run the pipeline, I get the error that pip and python3 are not recognised commands. Please help
Eduardo Alvarenga
May 30, 2022
Hello @Chong Jing Hong
Your scripts are probably lacking %PATH% declaration. You can either use the full path for each pip and python3 binaries or use the following variable substitution:
- %bamboo_capability_system_builder_py_pip% install BeautifulSoup4
- %bamboo_capability_system_builder_py_pip% install lxml
- %bamboo_capability_system_builder_py_pip% install requests
- %bamboo_capability_system_builder_python_Python38% broken_links.py
More info:
Eduardo Alvarenga
Atlassian Support APAC
Chong Jing Hong May 31, 2022
Thanks @Eduardo Alvarenga !
