Is there any way to get Bamboo use the correct path while executing a command. It appears that it adds some quote to a path and ends up displaying "no such file or directory" . For example to run stat on a location /xyz/xyz is there any thing that needs to be done. Is there any documentation on this ..
Hmm, so creating a Script Task with an Inline Script:
stat /xyz/xyz
doesn't work?
stat /xyz/*
doesn't work......
is there support for wildcard characters?
Have you typed it in as the script body (correct) or script arguments (incorrect)?
It should work, it's an oridnary shell script.
I have got a set of files under script directory, supprising on checking out these files using bamboo , it loses execute attribute. Fair enough now I am trying to apply these attribute using inline script. here the problem is that it can never find these files.
for example stat ${bamboo.build.working.directory}/* == No such file or directory
any help is much appreciated.
You are right I have typed it in argument, I just discovered scripts I am playing with this . Is there any documentation on how to setup Bamboo for make build system.
Thanks very much for your help
