Save Repository spins forever
Sebastian_R March 8, 2019 edited
Hi, I have problems adding Perforce to the linked repositories since the "Save Repository" spinner keeps spinning. First I added Perforce to the Server Capabilities C:\Program Files\Perforce\p4.exe). I can execute p4 commands on the command line. The system error view is empty. The entered perforce user is an admin. How can I find out what is causing this non-stopping "Save Repository" spinner? Thanks a lot!
Perforce Version: Helix P4V/NTX64/2018.3/1719707
Bamboo version: 6.8.0 build 60803 - 30 Jan 19
Victor Debone
March 11, 2019
Hello @Sebastian_R welcome to Atlassian Community :)
For your issue, do you have access to the directory where your Bamboo is installed? You will find more information about what could be causing the non-stopping spinner in the log file at `<bamboo install dir>/logs/bamboo.log` and understand better what may be causing this issue. If you need more help, you can paste the relevant piece here.
Victor
Victor Debone
March 11, 2019
I see @Sebastian_R that your first trial didn't work out, the system log is empty. Another attempt to check the errors is to look into the browser console while the spinner is continuously spinning. If you are not familiar with the process, you can find help for your browser here.
