Selenium Tests are running headless / background process in Bamboo application
Manikandan Periyasamy
April 2, 2023 edited
I am running my simple selenium tests inside Bamboo server and they are not running in in the foreground but the same was working in fine last two years. This problem is for last few months / weeks. Can you please help me if we have any bamboo version upgrade or any issues with Bamboo?
Eduardo Alvarenga
April 2, 2023
Hello @Manikandan Periyasamy
Welcome to Atlassian Community!
We recommend not publishing internal details from your Bamboo instance, such as URLs. The Atlassian Community is a public forum, and the information will be exposed.
As your issue relates to a specific build constraint, we recommend you log a ticket with Atlassian at https://support.atlassian.com/contact. Once there, you can provide internal details from your environment and a better description of the issue.
Sincerely,
Eduardo Alvarenga
Atlassian Support APAC
--please don't forget to Accept the answer if the reply is helpful--
April 5, 2023
