Specifying bamboo agent home generates Java error
Russell
Using the following command:
C:\Windows\SysWOW64\java -Dbamboo.home=C:\bamboo-agent-home -jar .\atlassian-bamboo-agent-installer-5.6.0.jar http://bamboo.url:8085/agentServer start
gives the error
Error: Could not find or load main class .home=C:\bamboo-agent-home
From Java and Atlassian docs this seems to be the correct command:
https://docs.oracle.com/javase/7/docs/technotes/tools/windows/java.html
https://confluence.atlassian.com/display/BAMBOO/Additional+remote+agent+options
https://confluence.atlassian.com/display/BAMBOO/Moving+Bamboo-Home+of+an+agent
We are not Java developers so it is not clear how to resolve the problem (my guess is that if we were, the answer would be obvious). Your assistance is requested.
Russell
The problem appears to be that Windows Powershell multilates "java -Dbamboo.home=<somedir> -jar <etc>" somehow. Using the regular Windows command line works fine.
Krystian Brazulewicz
November 12, 2014
Russel
Output from your command suggests there's a space or some other separator right after
I'm not sure how you executing this command. Do you type this in from command line or run from a batch file?
May I please ask you to type this command in from the command line (do not copy-paste)? Does it work? If it does then you batch file might contain some unprintable characters (result of copy-paste?) which confuse command line interpreter.
Russell
I did originally type the command on the command line, but to date I have been copying and pasting to the command line. I tried typing the command in full as you suggested and got the original ".home" related error.
rsperafico
November 12, 2014
Hello Russell,
It seems you have two Java installed on your Windows box.
If you run the following command you will be able to check under which path your "java -version" is running from:
which java
The above should display the same information as the following command:
echo %JAVA_HOME%
Please, make sure you are pointing to your Java SDK instead of JRE installation directory.
Rafael P. Sperafico
Atlassian Support
Russell
"which java" doesn't work in Windows. Sometimes "where java" does. I have a 64 bit system so I installed 64bit JDK for the Bamboo agent, but an application that it is to be as part of a job is 32 bit and requires Java so I also had to installed a 32 bit JRE. Hence the multiple Java installations.
rsperafico
November 12, 2014
Hello Russell,
Thank you for your question.
Could you please inform what Java SDK have you installed by running the following command from Command Prompt:
java -version
which java
Rafael P. Sperafico
Atlassian Support
Russell
"java -version" provides java version "1.7.0_72" Java(TM) SE Runtime Environment (build 1.7.0_72-b14) Java HotSpot(TM) 64-Bit Server VM (build 24.72-b04, mixed mode) and "C:\Windows\SysWOW64\java -version" provides java version "1.7.0_71" Java(TM) SE Runtime Environment (build 1.7.0_71-b14) Java HotSpot(TM) Client VM (build 24.71-b01, mixed mode, sharing)
