Substitute env variable in docker repository field
sta-szek
Is there any way to use env variables or anything that can be dynamically configured in repostiory field in docker build task?
e.g. repo/image:{tag}
2 accepted
Alexey Chystoprudov
February 27, 2018
Yes. It's possible since Bamboo v5.14.4.1. https://jira.atlassian.com/browse/BAM-15861
sta-szek
February 27, 2018 edited
Yes I saw that issues but it didn't work for me...
The key is I used: ${bamboo_variable} instead of ${bamboo.variable}
It's quite confusing that you have to use `.` instead of `_` especially when you see in logs:
`using extra environment variables .... bamboo_variable`
Steffen Opel _Utoolity_
You can reference Bamboo variables to achieve that, i.e. something like the following should work conceptually:
${bamboo.dockerRepository}/${bamboo.imageName}:${bamboo.buildNumber}
Please note that there used to be a few regressions with this in older Bamboo versions (e.g. BAM-15861 and BAM-18282), but I think the remaining ones have been addressed as of Bamboo 6.1.
