Hi
No emails are getting triggered post build run. I tried entering my mail id under Mail server and go below error:
The mail settings you entered were not valid. Error thrown was: com.sun.mail.util.MailConnectException: Couldn't connect to host, port: smtp.office365.com, 587; timeout 20000; nested exception is: java.net.SocketTimeoutException: connect timed out
Followed following KB article but could not get specific solution:
Do let me know if I need to send other logs. Pls suggest.
Manish
Hi Manish,
Looking at your error, it seems like a connectivity issue or configuration issue to me because "connect timed out"
You can test the mail using the CMD or terminal by command "telnet"
For example:
telnet smtp.office365.com 587
See if you can establish the connectivity from the machine where bamboo is hosted.
Hi Robhit
Thanks for your reply.
Tried running a ping command on our AWS server and got successfully message.
ping smtp.office.365.com 587 >> It threw error that 587 is bad parameter
ping smtp.office.365.com 587 >> it successfully pinged.
Pls suggest
Hi Manish,
There is a difference between Ping and telnet.
In short:
Ping: check connection (knock on the door of the remote server).
Telnet: gives access to the remote system if it is running telnet daemon.
And while using port 587 ping throws the error because it does not support that parameter.
Try executing the telnet command which I shared earlier. This will test the connectivity between your bamboo machine and the SMTP server if the port 587 which you are using is correct or open or not
Hi Robhit
Unfortunately I am not unable to use Telnet as its not configured. However, I am reaching out to my server team to see if this port in question ( 587) is blocked or not. Thanks
Hi Manish,
Update me on this!
And we will see if we can help you here.
Hi Robhit, With help of our IT team we were able to open port 587 and now mails are getting triggered. Thank you so much for suggesting this approach. You may pls go ahead and close this incident and send me survey link if possible.
You are five star bamboo guy!!
Manish
Hi Manish,
Good to know that it's working now.
However, this is community platform so no ticket and survey for this. But you can accept my answer so that others can also benefit from it.
Community work is to spread the help among the Atlassian users.
This learning path offers short, self-paced courses to help software teams systematically manage components and services. Compass provides a unified interface for tracking distributed software architecture and team collaboration.
Learn more!
