Upgrading psql 9.1 to 9.6 for Bamboo upgrade
admin admin
July 1, 2017
My Bamboo server was made into a monstrosity by its' previous admins and I now have to work to automate the process and clean it up.
To fix the ailing beast I need to upgrade psql 9.1 to 9.6 and retain all the present data in the database.
I will need to know how to export the data from psql 9.1 (which I believe I have now completed) as well as how to import the data into 9.6 such that bamboo can use the new database as the old one.
MoroSystems Support
August 3, 2017
standart mechanism is
https://www.postgresql.org/docs/9.1/static/backup-dump.html
You must have access to PostgreSQL and created folder with read/write permissions on OS.
Then for example:
    Export - pg_dump -U userdb namedb -f namefile.sql
    Import - psql -h localhost -U userdb -d namedb -f namefile.sql
After you configure bamboo.cfg.xml to new PostgreSQL and database.
https://confluence.atlassian.com/bamboo/changing-bamboo-database-settings-289277406.html
Moro support for AEVI
August 3, 2017
Hello
Przemek Bruski
July 1, 2017
You should be able to use the standard dump/restore mechanism of Postgres. Then just point Bamboo to the new database via bamboo.cfg.xml and you're good to go.
