i tried making new task into plan. but i don't understand what should be the path of executable path in nodejs.
I tried giving path of nodejs of my windows where nodejs is installed but it didn't work
Hi @aneesha_kumari,
I just setup this up this morning myself (we upgraded to the latest LTS version of node).
There were two things I did to ensure this was working properly:
1) I made sure the nodejs directory was correctly referenced in the system path variable
2) I set the server capability as follows:
That was all I needed to do to ensure that builds were capable of running npm tasks.
Are you able to share the error messages that you are seeing to help troubleshoot your issue?
-Jimmy
