I'd like to integrate existing regression test suites (trigged by script) with Bamboo after deploy buids to remote QA server. However, the current SCP task (Bamboo v4.2&4.3) only allow copy from Bamboo to remote server. I am curious why it is one way not both directions.
for work around, I am thinking about set up a SSH task to trigger a scp command from remote server to move files to Bamboo which is aweful but should do the trick.
Hey there, Shijun.
I noticed that it has been a while since you receive any response here. Have you raised a ticket in https://support.atlassian.com to seek help from the support engineers regarding the questions that you have here? If no, I would kindly suggest you to do so.
Hope this helps and all the best.
