Why do I get an Internal Error and a stack trace when running a deployment plan?
Jo Peel April 3, 2018
Running a deployment plan on Bamboo on Windows 10 I get an Internal Error and a stack trace (below). When I try to delete the plan I get another internal error and stack trace. Any ideas about how I should deal with this?
Version: 6.4.0
Build: 60404
Build Date: 17 Feb 2018
Request information:
  • Request URL: http://myBambooURL:myPort/deploy/executeManualDeployment.action
  • Scheme: http
  • Server: myBambooURL
  • Port: myPort
  • URI: /deploy/executeManualDeployment.action
  • Context path:
  • Servlet path: /deploy/executeManualDeployment.action
  • Path info:
  • Query string:
Stack Trace:
org.springframework.orm.hibernate5.HibernateSystemException: Cannot instantiate abstract class or interface:  : com.atlassian.bamboo.deployments.projects.persistence.items.AbstractMutableDeploymentProjectItem; nested exception is org.hibernate.InstantiationException: Cannot instantiate abstract class or interface:  : com.atlassian.bamboo.deployments.projects.persistence.items.AbstractMutableDeploymentProjectItem
	at org.springframework.orm.hibernate5.SessionFactoryUtils.convertHibernateAccessException(SessionFactoryUtils.java:296)
	at org.springframework.orm.hibernate5.HibernateTemplate.doExecute(HibernateTemplate.java:362)
	at org.springframework.orm.hibernate5.HibernateTemplate.execute(HibernateTemplate.java:313)
	at com.atlassian.bamboo.deployments.projects.persistence.DeploymentProjectDaoImpl.getProjectItems(DeploymentProjectDaoImpl.java:206)
	at sun.reflect.GeneratedMethodAccessor1628.invoke(Unknown Source)
	at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
	at java.lang.reflect.Method.invoke(Method.java:498)
	at org.springframework.aop.support.AopUtils.invokeJoinpointUsingReflection(AopUtils.java:333)
	at org.springframework.aop.framework.ReflectiveMethodInvocation.invokeJoinpoint(ReflectiveMethodInvocation.java:190)
	at org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:157)
	at org.springframework.transaction.interceptor.TransactionInterceptor$1.proceedWithInvocation(TransactionInterceptor.java:99)
	at org.springframework.transaction.interceptor.TransactionAspectSupport.invokeWithinTransaction(TransactionAspectSupport.java:282)
	at org.springframework.transaction.interceptor.TransactionInterceptor.invoke(TransactionInterceptor.java:96)
	at org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:179)
	at org.springframework.aop.framework.JdkDynamicAopProxy.invoke(JdkDynamicAopProxy.java:213)
	at com.sun.proxy.$Proxy89.getProjectItems(Unknown Source)
	at com.atlassian.bamboo.deployments.versions.service.DeploymentVersionServiceImpl$3.run(DeploymentVersionServiceImpl.java:454)
	at com.atlassian.bamboo.variable.CustomVariableContextImpl.withVariableSubstitutor(CustomVariableContextImpl.java:174)
	at com.atlassian.bamboo.deployments.versions.service.DeploymentVersionServiceImpl.getNewDeploymentVersionWithoutName(DeploymentVersionServiceImpl.java:447)
	at com.atlassian.bamboo.deployments.versions.service.DeploymentVersionServiceImpl.createDeploymentVersionInternal(DeploymentVersionServiceImpl.java:302)
	at com.atlassian.bamboo.deployments.versions.service.DeploymentVersionServiceImpl.access$000(DeploymentVersionServiceImpl.java:109)
	at com.atlassian.bamboo.deployments.versions.service.DeploymentVersionServiceImpl$2.apply(DeploymentVersionServiceImpl.java:280)
	at com.atlassian.bamboo.deployments.versions.service.DeploymentVersionServiceImpl$2.apply(DeploymentVersionServiceImpl.java:277)
	at com.atlassian.bamboo.core.ScopedExclusionServiceImpl.withLock(ScopedExclusionServiceImpl.java:63)
	at com.atlassian.bamboo.deployments.versions.service.DeploymentVersionServiceImpl.createDeploymentVersion(DeploymentVersionServiceImpl.java:277)
	at com.atlassian.bamboo.deployments.versions.actions.AbstractCreateDeploymentVersion.createVersion(AbstractCreateDeploymentVersion.java:117)
	at com.atlassian.bamboo.deployments.execution.actions.ExecuteManualDeployment.execute(ExecuteManualDeployment.java:210)
robhit
April 3, 2018
Hi Jo,
I believe you are hitting this known bug.
You can check the workaround mentioned.
Robhit
Jo Peel April 5, 2018
Hi Robhit,
Thank you for your quick response, spent some time with this yesterday and following the workaround in the bug BAM-19782 solved my problem,
Jo
