×I'm trying to set up many similar plans.
In order to copy them and not have to change all of them manually I want to use wildcards in directory names.
Eg. Two projects gba-vst-protokoll and gba-vst-psn both have webapps but with different names.
vstprotokoll-webapp and vstpsn-webapp.
In the compile Stage of the plans I want to publish an artifact containing the target directory of the webapp folder using an Artifact:
Copy Pattern: */
Shared: true
The build fails with this message:
Unable to publish artifact [webapp-target]: the source directory /home/bamboo/bamboo.home/xml-data/build-dir/GBA-PROTOKOLL-COMPILE/gba-vst-protokoll/*-webapp/target does not exist.
If I go to the server I can successfully reach the directory and see the expected content:
$ cd /home/bamboo/bamboo.home/xml-data/build-dir/GBA-PROTOKOLL-COMPILE/gba-vst-protokoll/*-webapp/target $ pwd /home/bamboo/bamboo.home/xml-data/build-dir/GBA-PROTOKOLL-COMPILE/gba-vst-protokoll/vstprotokoll-webapp/target $ ls classes generated-sources
Edit: If I set the Location to vstprotokoll-webapp/target then the build runs (so the data is definitely there). It's just a pain to do this for 10 to 50 Projects...
Is it possible to use wildcards in directory / location names for artifacts?
Note: using a wildcard in the destination folder for an artifact works...
So I can have an artifact successfully copied to *-webapp/target but not from *-webapp/target?
The same question applies to Stage - Job - Task - Working Sub Directory.
I have a lot of projects that have a <name>-db directory out of which database patches need to run. I'd like to set up a task that runs in *-db so that I can copy this around and save setup times, and not be tied to the actual project name.
Cheers
Jack...
I opened a support request for this, and the answer ist to use Plan or Bamboo variable instead of wildcards.
Cheers
Jack...
For reference, here is the juicy part of the support ticket (#BSP-6577):
My first idea is to use Bamboo Variables in Location and Destination fields
${bamboo.webappname}-webapp/target
and then give that variable a proper value on a Plan level.
Please let us know if that is viable solution.
Cheers
Krystian Brazulewicz
Atlassian Bamboo Development
