Work with Java 8 and Java 11 in the same machine
gbdavid2 August 3, 2020
I understand that Bamboo is still not compatible with Java 11.
I have some software in my server that requires Java 11 to work, but I also have Bamboo in the same server. I know you can install both. Java 8 and Java 11 and keep them at the same time...
For the JAVA_HOME variable (Windows Server 2012), I see I can add multiple entries, but that won't necessarily mean that Bamboo will find the compatible one in the list?
It there a setup or arrangement I can do in my server so that Bamboo detects there's a Java 8 and uses it, and the other Software uses Java 11? (I can't edit anything in the other software, so the default pointers/variables must direct to Java 11 so that the other software detects it).
Erick Johanson
August 3, 2020 edited
i think you need to edit some config file, there are options to set envionment (i know from jira) you can set in config file where java_home which one to use, i think this way can be correct or looking for solution to set env for (bamboo user)
bamboo directory and files
https://confluence.atlassian.com/bamboo/locating-important-directories-and-files-289277247.html
plan B
found something maybe will helps
https://stackoverflow.com/questions/26993101/switching-between-different-jdk-versions-in-windows
There are some code block that said how to
The set command only works for the current terminal. To permanently set a system or user environment variable you can use setx.
setx JAVA_HOME "C:\Program Files\Java\jdk1.7.0_72" /m
setx doc:
https://docs.microsoft.com/en-us/windows-server/administration/windows-commands/setx
p.s. test it on stage before prod, and make backup copy of config files
