×Please help me in below problem.
Our stash and bamboo application links working properly and building plan till last Friday.
Our stash and bamboo URL got changed now , we removed application links and recreated application links with new URL. After that none of build plans were not working.
Throwing below error and we did "Save the repository configuration" but didn't fix issue.
Please help me if any one of you ran into same problem.
Stash 3.3.0 and bamboo 5.8.1
image2016-9-28 16:29:34.png
Here is log message
com.atlassian.bamboo.repository.RepositoryException: java.lang.RuntimeException: com.atlassian.bamboo.plugins.stash.repository.StashRepositoryException: com.atlassian.bamboo.repository.RepositoryException: com.atlassian.bamboo.plugins.git.GitCommandException: command 'C:\Program Files (x86)\Git\cmd\git.exe' ls-remote ssh://ef157b6c-2fe6-4781-9960-1a15efb97ca5@127.0.0.1:28970/dtech/text-paging.git failed with code 128. Working directory was [.]., stderr: Error while opening SSH session stdout: [Warning: Permanently added '[127.0.0.1]:28970' (RSA) to the list of known hosts., BAMBOO-SSH-PROXY: [While connecting to [git@bitbucket.dtech.saccounty.net/10.94.72.177:7999]: Error while opening SSH session: org.apache.sshd.common.RuntimeSshException: Failed to get the session.], fatal: Could not read from remote repository., , Please make sure you have the correct access rights, and the repository exists.] at com.atlassian.bamboo.v2.trigger.DefaultChangeDetectionManager.collectChangesSinceLastBuildInternal(DefaultChangeDetectionManager.java:398)
I suggest you to remove application link directly from database:
Follow this docement
