I have an angular app that I'm building, when I run the build command ng --aot build directly through the terminal, it runs fine, but through the bamboo script task it gives
panic: aborting due to terminal initialize failureAborted (core dumped)I tried increasing the jvm memory settings in {install_dir}/bin/setenv.sh JVM_MINIMUM_MEMORY and JVM_MAXIMUM_MEMORY to 2048m and 8192m respectively..same error
node v13.12.0
npm 6.14.4
Angular: 9.1.6
