We are currently using the following tools for out CI, automated deployment/testing:
Perforce, CruiseControl.net, InstallShield, VisualBuildPro, QTP, Visual Studio.
If we start using Bamboo as a main CI server, which of our tools can be integrated with bamboo and which can be replaced by bamboo completely.
thanks
Check this out: http://www.atlassian.com/software/bamboo/overview/plugins-integration
You'll see some available plugins that will provide you integration. And this http://www.atlassian.com/software/bamboo/features will show you all the features, so you need to compare with what the other tools do. Feel free to write a few lines about the functionares you use on those products and I will help to figure whether Bamboo does that or not.
Bamboo can completely replace CruiseControl.net and has excellent support for Visual Studio and Perforce. Bamboo can also call out to QTP, InstallSheild and VisualBuildPro using a Script task so that they are executed as part of the build process.
great, thank you, James!
