deploy maven artifact to artifactory
Simar Arora
April 5, 2017
I have a maven module which gets built in build plan of Bamboo and want to deploy the artifact produced on artifactory, in deploy plan instead of build plan. Is it possible?
I tried using Bamboo Artifactory Plugin. The problem is the plugin uploads the artifact produced as jar and not as maven module
if I do not use the plugin and simply use maven3.x (mvn deploy) task it works in the build plan but not in deployment plan.
Any ideas would be really appreciated.
Yasemin Dogan
February 4, 2019
I have the same problem.
Its possible to deploy into the artifactory and check the box with "deploy as maven artifact" to get dependency declaration of the .war.
I tried several ways through bamboo to deploy a .war artifact with those declarations, but no success.
Help.
