We have Upgraded our bamboo version from 5.9.7 to 6.10.4. Due to a number of deprecations and removals in the API, our plugin codebase has been effected. Found a specific code segment needs to be updated and Not sure if there are any other changes also we need to do so.
package com.atg.bamboo.plugins.web.condition;
import com.atlassian.bamboo.plan.Plan;
import com.atlassian.bamboo.plan.PlanHelper;
import com.atlassian.bamboo.plan.PlanManager;
import com.atlassian.bamboo.repository.Repository;
import com.atlassian.plugin.PluginParseException;
import com.atlassian.plugin.web.Condition;
import org.apache.log4j.Logger;
import java.util.List;
import java.util.Map;
* @author ddziamen
public class DetailedStatusTabCondition implements Condition {
private static final Logger log = Logger.getLogger(DetailedStatusTabCondition.class);
private PlanManager planManager;
public void init(Map params) throws PluginParseException {
* (@return true only if it is Devtools repositor
public boolean shouldDisplay(Map context) {
String buildKey = context.get("buildKey") != null ? (String)context.get("buildKey") : null;
Plan plan = planManager.getPlanByKey(buildKey);
List<Repository> repositories = PlanHelper.getRepositories(plan);
for(Repository repository : repositories) {
if(repository.getKey().endsWith("devtoolsP4")) return true;
return false;
public void setPlanManager(PlanManager planManager) {
this.planManager = planManager;
Is there a way to replace the above or any alternative to modify the code.
References: getRepositories(ImmutablePlan plan) is not there in 6.10.4 version Bamboo.
https://docs.atlassian.com/atlassian-bamboo/5.9.7/com/atlassian/bamboo/plan/PlanHelper.html
https://docs.atlassian.com/atlassian-bamboo/6.10.4/com/atlassian/bamboo/plan/PlanHelper.html
Please try this:
import com.atlassian.bamboo.plan.PlanKeys;
import com.atlassian.bamboo.plan.cache.CachedPlanManager;
import com.atlassian.bamboo.plan.cache.ImmutablePlan;
import com.atlassian.bamboo.vcs.configuration.PlanRepositoryDefinition;
import org.apache.commons.lang3.StringUtils;
import org.springframework.beans.factory.annotation.Autowired;
* @author ddziamen
@Autowired
private CachedPlanManager planManager;
* (@return true only if it is Devtools repository
final String buildKey = StringUtils.defaultString((String) context.get("planKey"), (String) context.get("buildKey"));
if (buildKey == null) {
return false;
ImmutablePlan plan = planManager.getPlanByKey(PlanKeys.getPlanKey(buildKey));
List<PlanRepositoryDefinition> repositories = PlanHelper.getPlanRepositoryDefinitions(plan);
for(PlanRepositoryDefinition repository : repositories) {
if (repository.getPluginKey().endsWith("devtoolsP4")) {
return true;
return false;
You might need to add apache.commons.lang3 as a dependency to your plugin or replace StringUtils call with equivalent conditional expression.
Hi Marcin Gardias, Thanks for your inputs.
We have tried using the above code in our latest Bamboo(6.10.4). It's failing to execute the plugin, and as result it is throwing java.lang.NullPointerException in logs.
I'm suspecting something must be changed here. Could you please have a look.
return false;
Below are the logs from Bamboo Server:
2019-12-05 00:22:47,280 ERROR [ajp-nio-8009-exec-8] [DefaultWebInterfaceManager] Could not evaluate condition 'com.atg.bamboo.plugins.web.condition.DetailedStatusTabCondition@6ff7a10e' for descriptor: atg.bamboo.plugins.DevtoolsIntegration:detailedStatus:${plan.key}-${resultsSummary.buildNumber} (null)
at com.atg.bamboo.plugins.web.condition.DetailedStatusTabCondition.shouldDisplay(DetailedStatusTabCondition.java:39)
at com.atlassian.plugin.web.DefaultWebInterfaceManager.filterFragmentsByCondition(DefaultWebInterfaceManager.java:153)
at com.atlassian.plugin.web.DefaultWebInterfaceManager.getDisplayableItems(DefaultWebInterfaceManager.java:106)
at com.atlassian.bamboo.ww2.BambooActionSupport.getWebItemsForSection(BambooActionSupport.java:417)
at sun.reflect.GeneratedMethodAccessor1418.invoke(Unknown Source)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
at java.lang.reflect.Method.invoke(Method.java:498)
at freemarker.ext.beans.BeansWrapper.invokeMethod(BeansWrapper.java:1459)
at freemarker.ext.beans.SimpleMethodModel.exec(SimpleMethodModel.java:69)
at freemarker.core.MethodCall._eval(MethodCall.java:76)
at freemarker.core.Expression.eval(Expression.java:81)
at freemarker.core.Assignment.accept(Assignment.java:134)
at freemarker.core.Environment.visit(Environment.java:362)
at freemarker.core.IteratorBlock$IterationContext.executeNestedContent(IteratorBlock.java:239)
at freemarker.core.IteratorBlock$IterationContext.accept(IteratorBlock.java:200)
at freemarker.core.Environment.visitIteratorBlock(Environment.java:595)
at freemarker.core.IteratorBlock.acceptWithResult(IteratorBlock.java:81)
at freemarker.core.IteratorBlock.accept(IteratorBlock.java:67)
at freemarker.core.Environment.invoke(Environment.java:714)
at freemarker.core.UnifiedCall.accept(UnifiedCall.java:86)
at freemarker.core.Environment.visit(Environment.java:326)
at freemarker.core.Environment.visit(Environment.java:368)
at freemarker.core.Environment.visitAndTransform(Environment.java:460)
at freemarker.core.BlockAssignment.accept(BlockAssignment.java:55)
at freemarker.core.Environment.visit(Environment.java:332)
at freemarker.core.Environment.process(Environment.java:305)
at freemarker.template.Template.process(Template.java:384)
at com.atlassian.bamboo.ww2.FreemarkerRequestDispatcherPageFilter.applyDecorator(FreemarkerRequestDispatcherPageFilter.java:123)
at org.apache.struts2.sitemesh.TemplatePageFilter.applyDecorator(TemplatePageFilter.java:116)
at com.atlassian.bamboo.ww2.FreemarkerRequestDispatcherPageFilter.access$200(FreemarkerRequestDispatcherPageFilter.java:46)
at com.atlassian.bamboo.ww2.FreemarkerRequestDispatcherPageFilter$BambooSitemeshDecorator.render(FreemarkerRequestDispatcherPageFilter.java:245)
at com.opensymphony.sitemesh.webapp.decorator.BaseWebAppDecorator.render(BaseWebAppDecorator.java:33)
at com.opensymphony.sitemesh.webapp.SiteMeshFilter.doFilter(SiteMeshFilter.java:84)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:193)
at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:166)
at com.atlassian.bamboo.filter.SessionCreationForAnonymousUserFilter.doFilter(SessionCreationForAnonymousUserFilter.java:40)
at com.atlassian.bamboo.filter.NewRelicTransactionNamingFilter.doFilter(NewRelicTransactionNamingFilter.java:30)
at com.atlassian.bamboo.ww2.StrutsPrepareFilter$1.doFilter(StrutsPrepareFilter.java:72)
at org.apache.struts2.dispatcher.filter.StrutsPrepareFilter.doFilter(StrutsPrepareFilter.java:92)
at com.atlassian.bamboo.ww2.StrutsPrepareFilter.handleRequest(StrutsPrepareFilter.java:46)
at com.atlassian.bamboo.ww2.StrutsPrepareFilter.doFilter(StrutsPrepareFilter.java:38)
at com.atlassian.bamboo.filter.BambooProfilingFilter.doFilter(BambooProfilingFilter.java:72)
at com.atlassian.plugin.servlet.filter.IteratingFilterChain.doFilter(IteratingFilterChain.java:39)
at com.atlassian.plugin.servlet.filter.DelegatingPluginFilter$1.doFilter(DelegatingPluginFilter.java:58)
at com.atlassian.prettyurls.filter.PrettyUrlsCombinedMatchDispatcherFilter.doFilter(PrettyUrlsCombinedMatchDispatcherFilter.java:56)
at com.atlassian.plugin.servlet.filter.DelegatingPluginFilter.doFilter(DelegatingPluginFilter.java:64)
at com.atlassian.plugin.servlet.filter.IteratingFilterChain.doFilter(IteratingFilterChain.java:37)
at com.atlassian.plugin.servlet.filter.ServletFilterModuleContainerFilter.doFilter(ServletFilterModuleContainerFilter.java:70)
at com.atlassian.plugin.servlet.filter.ServletFilterModuleContainerFilter.doFilter(ServletFilterModuleContainerFilter.java:58)
at com.atlassian.bamboo.filter.AccessLogFilter.doFilter(AccessLogFilter.java:89)
at org.acegisecurity.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:265)
at org.acegisecurity.providers.anonymous.AnonymousProcessingFilter.doFilter(AnonymousProcessingFilter.java:125)
at org.acegisecurity.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:275)
at com.atlassian.bamboo.filter.SeraphLoginFilter$1.run(SeraphLoginFilter.java:71)
at com.atlassian.bamboo.security.ImpersonationHelper.runWith(ImpersonationHelper.java:26)
at com.atlassian.bamboo.security.ImpersonationHelper.runAs(ImpersonationHelper.java:54)
at com.atlassian.bamboo.filter.SeraphLoginFilter.doFilter(SeraphLoginFilter.java:76)
at org.acegisecurity.util.FilterChainProxy.doFilter(FilterChainProxy.java:149)
at org.acegisecurity.util.FilterToBeanProxy.doFilter(FilterToBeanProxy.java:98)
at com.atlassian.bamboo.filter.BambooAcegiProxyFilter.doFilter(BambooAcegiProxyFilter.java:21)
at com.atlassian.bamboo.filter.LicenseFilter.doFilter(LicenseFilter.java:74)
at com.atlassian.core.filters.AbstractHttpFilter.doFilter(AbstractHttpFilter.java:31)
at com.atlassian.johnson.filters.AbstractJohnsonFilter.doFilter(AbstractJohnsonFilter.java:59)
at com.atlassian.seraph.filter.SecurityFilter.doFilter(SecurityFilter.java:242)
at com.atlassian.seraph.filter.BaseLoginFilter.doFilter(BaseLoginFilter.java:148)
at com.atlassian.seraph.filter.BambooLoginFilter.doFilter(BambooLoginFilter.java:37)
at com.atlassian.oauth.serviceprovider.internal.servlet.OAuthFilter.doFilter(OAuthFilter.java:67)
at org.springframework.orm.hibernate5.support.OpenSessionInViewFilter.doFilterInternal(OpenSessionInViewFilter.java:152)
at com.atlassian.bamboo.persistence.BambooSessionInViewFilter.doFilterInternal(BambooSessionInViewFilter.java:24)
at org.springframework.web.filter.OncePerRequestFilter.doFilter(OncePerRequestFilter.java:107)
at com.github.ziplet.filter.compression.CompressingFilter.doFilter(CompressingFilter.java:304)
at com.atlassian.bamboo.filter.BambooCompressingFilter.doFilter(BambooCompressingFilter.java:37)
at com.atlassian.bamboo.filter.RequestCacheThreadLocalFilter.doFilter(RequestCacheThreadLocalFilter.java:40)
at com.atlassian.bamboo.filter.ClickjackingAndMimeTypeSniffingPreventionFilter.doFilter(ClickjackingAndMimeTypeSniffingPreventionFilter.java:36)
at com.atlassian.bamboo.filter.CookieCacheControlFilter.doFilter(CookieCacheControlFilter.java:49)
at com.atlassian.core.filters.HeaderSanitisingFilter.doFilter(HeaderSanitisingFilter.java:32)
at org.apache.catalina.core.ApplicationDispatcher.invoke(ApplicationDispatcher.java:728)
at org.apache.catalina.core.ApplicationDispatcher.processRequest(ApplicationDispatcher.java:470)
at org.apache.catalina.core.ApplicationDispatcher.doForward(ApplicationDispatcher.java:395)
at org.apache.catalina.core.ApplicationDispatcher.forward(ApplicationDispatcher.java:316)
at com.atlassian.bamboo.filter.UrlRewriteFilter.forwardTo(UrlRewriteFilter.java:314)
at com.atlassian.bamboo.filter.UrlRewriteFilter.doFilter(UrlRewriteFilter.java:199)
at com.atlassian.core.filters.HeaderSanitisingFilter.doFilter(HeaderSanitisingFilter.java:44)
at com.atlassian.analytics.client.filter.DefaultAnalyticsFilter.doFilter(DefaultAnalyticsFilter.java:38)
at com.atlassian.analytics.client.filter.AbstractHttpFilter.doFilter(AbstractHttpFilter.java:39)
at org.springframework.web.filter.CharacterEncodingFilter.doFilterInternal(CharacterEncodingFilter.java:200)
at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:199)
at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:96)
at org.apache.catalina.authenticator.AuthenticatorBase.invoke(AuthenticatorBase.java:493)
at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:137)
at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:81)
at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:87)
at org.apache.catalina.valves.StuckThreadDetectionValve.invoke(StuckThreadDetectionValve.java:206)
at org.apache.catalina.valves.AbstractAccessLogValve.invoke(AbstractAccessLogValve.java:660)
at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:343)
at org.apache.coyote.ajp.AjpProcessor.service(AjpProcessor.java:476)
at org.apache.coyote.AbstractProcessorLight.process(AbstractProcessorLight.java:66)
at org.apache.coyote.AbstractProtocol$ConnectionHandler.process(AbstractProtocol.java:808)
at org.apache.tomcat.util.net.NioEndpoint$SocketProcessor.doRun(NioEndpoint.java:1498)
at org.apache.tomcat.util.net.SocketProcessorBase.run(SocketProcessorBase.java:49)
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1142)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:617)
at org.apache.tomcat.util.threads.TaskThread$WrappingRunnable.run(TaskThread.java:61)
at java.lang.Thread.run(Thread.java:745)
Thanks in advance.
I think you need to add a component import for CachedPlanManager to your plugin. You either need to add it to atlassian-plugin.xml or use @ComponentImport annotation, use whatever approach is already used in your plugin.
