how to change build requirements per branch?
Laert Pires January 29, 2015
With a plan with multiple branches that run builds in parallel is there a way to change the build requirements per branch? I specifically want to set a requirement based on a branch variable to enforce the builds to run on specific servers.
rsperafico
January 30, 2015
Hello Laert,
Thank you for your question.
Regarding to your question: is there a way to change the build requirements per branch?, no, the requirements are set up in the job level and you cannot change it to behave differently in an individual branch, I am afraid.
If you find this answer useful, I would kindly ask you to accept it so the same will be visible to others who might be facing the same issue you have inquired.
Thank you for your understanding.
Rafael P. Sperafico
Atlassian Support
