Sign up Log in
how to use atlas-mvn eclipse:eclipse in bamboo builds?
Vedant Kulkarni
We are building plugin for jira in Bamboo by fetching code from Bitbucket repo and I need to connect Eclipse IDE so that all jira plugin will be in one place and it will be easy to resolve the errors.
When I fire atlas-mvn eclipse:eclipse command in the directory where I have fetched the code from Repo to local system then it is giving below error:-
Executing: "C:\Applications\Atlassian\atlassian-plugin-sdk-6.3.4\apache-maven-3.2.1\bin\mvn.bat" -gs C:\Applications\Atlassian\atlassian-plugin-sdk-6.3.4\apache-maven-3.2.1/conf/settings.xml eclipse:eclipse
Java HotSpot(TM) Client VM warning: ignoring option MaxPermSize=256M; support was removed in 8.0
[INFO] Scanning for projects...
[ERROR] The build could not read 13 projects -> [Help 1]
[ERROR]
[ERROR] The project com.sac.pc.jira:pc-jira-issue:1837.2.12.${build.number} (C:\Users\VK8577\Documents\pcsystem\sac-pc\pc-jira\pc-jira-issue\pom.xml) has 3 errors
[ERROR] 'dependencies.dependency.version' for com.sac.pc:pc-salesforce:jar must be a valid version but is '1837.2.12.${build.number}'. @ com.sac.pc.jira:pc-jira-issue:${sac.version}, C:\Users\VK8577\Documents\pcsystem\sac-pc\pc-jira\pc-jira-issue\pom.xml, line 128, column 22
[ERROR] 'dependencies.dependency.version' for com.sac.pc:model:jar must be a valid version but is '1837.2.12.${build.number}'. @ com.sac.pc.jira:pc-jira-issue:${sac.version}, C:\Users\VK8577\Documents\pcsystem\sac-pc\pc-jira\pc-jira-issue\pom.xml, line 153, column 22
[ERROR] 'dependencies.dependency.version' for com.sac.pc.jira.notification:pc-jira-notification:jar must be a valid version but is '1837.2.12.${build.number}'. @ com.sac.pc.jira:pc-jira-issue:${sac.version}, C:\Users\VK8577\Documents\pcsystem\sac-pc\pc-jira\pc-jira-issue\pom.xml, line 159, column 22
[ERROR]
[ERROR] The project com.sac.pc.jira:pc-jira-pcazman:1837.2.12.${build.number} (C:\Users\VK8577\Documents\pcsystem\sac-pc\pc-jira\pc-jira-pcazman\pom.xml) has 1 error
[ERROR] 'dependencies.dependency.version' for com.sac.pc:model:jar must be a valid version but is '1837.2.12.${build.number}'. @ com.sac.pc.jira:pc-jira-pcazman:${sac.version}, C:\Users\VK8577\Documents\pcsystem\sac-pc\pc-jira\pc-jira-pcazman\pom.xml, line 74, column 13
[ERROR]
[ERROR] The project com.sac.pc.jira:pc-jira-email:1837.2.12.${build.number} (C:\Users\VK8577\Documents\pcsystem\sac-pc\pc-jira\pc-jira-email\pom.xml) has 2 errors
[ERROR] 'dependencies.dependency.version' for com.sac.pc:model:jar must be a valid version but is '1837.2.12.${build.number}'. @ com.sac.pc.jira:pc-jira-email:${sac.version}, C:\Users\VK8577\Documents\pcsystem\sac-pc\pc-jira\pc-jira-email\pom.xml, line 74, column 13
[ERROR] 'dependencies.dependency.version' for com.sac.pc.jira.notification:pc-jira-notification:jar must be a valid version but is '1837.2.12.${build.number}'. @ com.sac.pc.jira:pc-jira-email:${sac.version}, C:\Users\VK8577\Documents\pcsystem\sac-pc\pc-jira\pc-jira-email\pom.xml, line 80, column 13
[ERROR]
[ERROR] The project com.sac.pc.jira.operation.items:pc-web-items:1837.2.12.${build.number} (C:\Users\VK8577\Documents\pcsystem\sac-pc\pc-jira\pc-web-items\pom.xml) has 1 error
[ERROR] 'dependencies.dependency.version' for com.sac.pc:model:jar must be a valid version but is '1837.2.12.${build.number}'. @ com.sac.pc.jira.operation.items:pc-web-items:${sac.version}, C:\Users\VK8577\Documents\pcsystem\sac-pc\pc-jira\pc-web-items\pom.xml, line 53, column 22
[ERROR]
[ERROR] The project com.sac.pc.jira.servlet.clone_pc:pc-clone-servlet:1837.2.12.${build.number} (C:\Users\VK8577\Documents\pcsystem\sac-pc\pc-jira\clone-pc-servlet\pom.xml) has 2 errors
[ERROR] 'dependencies.dependency.version' for com.sac.pc:model:jar must be a valid version but is '1837.2.12.${build.number}'. @ com.sac.pc.jira.servlet.clone_pc:pc-clone-servlet:${sac.version}, C:\Users\VK8577\Documents\pcsystem\sac-pc\pc-jira\clone-pc-servlet\pom.xml, line 22, column 13
[ERROR] 'dependencies.dependency.version' for com.sac.pc.jira.operation.items:pc-web-items:jar must be a valid version but is '1837.2.12.${build.number}'. @ com.sac.pc.jira.servlet.clone_pc:pc-clone-servlet:${sac.version}, C:\Users\VK8577\Documents\pcsystem\sac-pc\pc-jira\clone-pc-servlet\pom.xml, line 28, column 13
[ERROR]
[ERROR] The project com.sac.pc.jira.servlet.create_pc:create-pc-jira-servlet:1837.2.12.${build.number} (C:\Users\VK8577\Documents\pcsystem\sac-pc\pc-jira\create-pc-jira-servlet\pom.xml) has 3 errors
[ERROR] 'dependencies.dependency.version' for com.sac.pc:model:jar must be a valid version but is '1837.2.12.${build.number}'. @ com.sac.pc.jira.servlet.create_pc:create-pc-jira-servlet:${sac.version}, C:\Users\VK8577\Documents\pcsystem\sac-pc\pc-jira\create-pc-jira-servlet\pom.xml, line 22, column 13
[ERROR] 'dependencies.dependency.version' for com.sac.pc.jira.operation.items:pc-web-items:jar must be a valid version but is '1837.2.12.${build.number}'. @ com.sac.pc.jira.servlet.create_pc:create-pc-jira-servlet:${sac.version}, C:\Users\VK8577\Documents\pcsystem\sac-pc\pc-jira\create-pc-jira-servlet\pom.xml, line 28, column 13
[ERROR] 'dependencies.dependency.version' for com.sac.pc.jira:pc-project-tags:jar must be a valid version but is '1837.2.12.${build.number}'. @ com.sac.pc.jira.servlet.create_pc:create-pc-jira-servlet:${sac.version}, C:\Users\VK8577\Documents\pcsystem\sac-pc\pc-jira\create-pc-jira-servlet\pom.xml, line 34, column 22
[ERROR]
[ERROR] The project com.sac.pc.jira.notification:pc-jira-notification:1837.2.12.${build.number} (C:\Users\VK8577\Documents\pcsystem\sac-pc\pc-jira\pc-jira-notification\pom.xml) has 1 error
[ERROR] 'dependencies.dependency.version' for com.sac.pc.jira.operation.items:pc-web-items:jar must be a valid version but is '1837.2.12.${build.number}'. @ com.sac.pc.jira.notification:pc-jira-notification:${sac.version}, C:\Users\VK8577\Documents\pcsystem\sac-pc\pc-jira\pc-jira-notification\pom.xml, line 49, column 22
[ERROR]
[ERROR] The project com.sac.pc.jira.customfield:pc-efforttype-cf:1837.2.12.${build.number} (C:\Users\VK8577\Documents\pcsystem\sac-pc\pc-jira\pc-efforttype-cf\pom.xml) has 1 error
[ERROR] 'dependencies.dependency.version' for com.sac.pc:model:jar must be a valid version but is '1837.2.12.${build.number}'. @ com.sac.pc.jira.customfield:pc-efforttype-cf:${sac.version}, C:\Users\VK8577\Documents\pcsystem\sac-pc\pc-jira\pc-efforttype-cf\pom.xml, line 107, column 22
[ERROR]
[ERROR] The project com.sac.pc.jira.customfield:pc-samapplication-cf:1837.2.12.${build.number} (C:\Users\VK8577\Documents\pcsystem\sac-pc\pc-jira\pc-samapplication-cf\pom.xml) has 1 error
[ERROR] 'dependencies.dependency.version' for com.sac.pc:model:jar must be a valid version but is '1837.2.12.${build.number}'. @ com.sac.pc.jira.customfield:pc-samapplication-cf:${sac.version}, C:\Users\VK8577\Documents\pcsystem\sac-pc\pc-jira\pc-samapplication-cf\pom.xml, line 117, column 22
[ERROR]
[ERROR] The project com.sac.pc.jira:pc-project-tags:1837.2.12.${build.number} (C:\Users\VK8577\Documents\pcsystem\sac-pc\pc-jira\pc-project-tags\pom.xml) has 1 error
[ERROR] 'dependencies.dependency.version' for com.sac.pc:model:jar must be a valid version but is '1837.2.12.${build.number}'. @ com.sac.pc.jira:pc-project-tags:${sac.version}, C:\Users\VK8577\Documents\pcsystem\sac-pc\pc-jira\pc-project-tags\pom.xml, line 22, column 13
[ERROR]
[ERROR] The project com.sac.pc.jira:pc-material-amendments:1837.2.12.${build.number} (C:\Users\VK8577\Documents\pcsystem\sac-pc\pc-jira\pc-material-amendments\pom.xml) has 3 errors
[ERROR] 'dependencies.dependency.version' for com.sac.pc:model:jar must be a valid version but is '1837.2.12.${build.number}'. @ com.sac.pc.jira:pc-material-amendments:${sac.version}, C:\Users\VK8577\Documents\pcsystem\sac-pc\pc-jira\pc-material-amendments\pom.xml, line 22, column 22
[ERROR] 'dependencies.dependency.version' for com.sac.pc.jira.customfield:pc-samapplication-cf:jar must be a valid version but is '1837.2.12.${build.number}'. @ com.sac.pc.jira:pc-material-amendments:${sac.version}, C:\Users\VK8577\Documents\pcsystem\sac-pc\pc-jira\pc-material-amendments\pom.xml, line 89, column 22
[ERROR] 'dependencies.dependency.version' for com.sac.pc.jira.customfield:pc-department-cf:jar must be a valid version but is '1837.2.12.${build.number}'. @ com.sac.pc.jira:pc-material-amendments:${sac.version}, C:\Users\VK8577\Documents\pcsystem\sac-pc\pc-jira\pc-material-amendments\pom.xml, line 95, column 22
[ERROR]
[ERROR] The project com.sac.pc.jira.customfield:pc-department-cf:1837.2.12.${build.number} (C:\Users\VK8577\Documents\pcsystem\sac-pc\pc-jira\pc-department-cf\pom.xml) has 1 error
[ERROR] 'dependencies.dependency.version' for com.sac.pc:model:jar must be a valid version but is '1837.2.12.${build.number}'. @ com.sac.pc.jira.customfield:pc-department-cf:${sac.version}, C:\Users\VK8577\Documents\pcsystem\sac-pc\pc-jira\pc-department-cf\pom.xml, line 130, column 22
[ERROR]
[ERROR] The project com.sac.pc.jira:pc-pluralsight-reports:1837.2.12.${build.number} (C:\Users\VK8577\Documents\pcsystem\sac-pc\pc-jira\pc-pluralsight-reports\pom.xml) has 1 error
[ERROR] 'dependencies.dependency.version' for com.sac.pc:model:jar must be a valid version but is '1837.2.12.${build.number}'. @ com.sac.pc.jira:pc-pluralsight-reports:${sac.version}, C:\Users\VK8577\Documents\pcsystem\sac-pc\pc-jira\pc-pluralsight-reports\pom.xml, line 83, column 22
[ERROR]
[ERROR] To see the full stack trace of the errors, re-run Maven with the -e switch.
[ERROR] Re-run Maven using the -X switch to enable full debug logging.
[ERROR]
[ERROR] For more information about the errors and possible solutions, please read the following articles:
[ERROR] [Help 1] http://cwiki.apache.org/confluence/display/MAVEN/ProjectBuildingException
Anybody can help me out?
Rafael Pinto Sperafico
March 19, 2019
Hi @Vedant Kulkarni ,
The error suggest dependencies cannot be found:
Perhaps you could review if the versions you are given to your dependencies are correct and that your maven repository has those dependencies, if not, when issuing the atlas-mvn, maven will attempt on connecting with the repositories you have specified in C:\Applications\Atlassian\atlassian-plugin-sdk-6.3.4\apache-maven-3.2.1/conf/settings.xml.
For instance, from which Maven repository you are getting the dependency:
<dependency>
<groupId>com.sac.pc</groupId>
<artifactId>pc-salesforce</artifactId>
<version>1837.02.12.${build.number}</version>
</dependency>
For more information, please have a look at https://developer.atlassian.com/server/framework/atlassian-sdk/working-with-maven/
Rafael
Vedant Kulkarni
Hi @Rafael Pinto Sperafico
Thanks for the response.
This dependency com.sac.pc is on the local system and the version is changing according to Bamboo builds. That's why I am not getting how should I use in bamboo builds without these errors.
Vedant
March 19, 2019
So you are building those dependencies (e.g com.sac.pc:pc-salesforce:1837.02.12.xxx) before calling atlas-mvn command? Meaning that if you go to the local Maven repository the dependency must be available in there so it can be used in by <dependency/> tag.
You must provided a dependency version that exists and can be referred, otherwise Maven will fail as it cannot find the version specified.
First of all, search for the dependency pc-salesforce in the box where you are running the command atlas-mvn and list all the version(s) available. If you find any, get the existent version and hardcode it to your pom.xml file. If you do not find any, search for the dependency in the repository you have specified in settings.xml and use the version you can find.
Please, have a look at https://maven.apache.org/guides/introduction/introduction-to-repositories.html
Rafael
Vedant Kulkarni
Yes correct I am building it before calling altas-mvn but I am building all plugin using one job in Bamboo because all are interdependent.
As you said, to provide a dependency version but version changes after every build so how should I use it?
Thanks,V
Vedant
March 19, 2019
Thank you for your update.
Since you are building those dependency, you could have them installed in the Local Maven repository (https://maven.apache.org/guides/mini/guide-3rd-party-jars-local.html) upon compiled.
Check what is the local repository defined in C:\Applications\Atlassian\atlassian-plugin-sdk-6.3.4\apache-maven-3.2.1/conf/settings.xml or %USERPROFILE%\.m2\settings.xml
<!-- localRepository
| The path to the local repository maven will use to store artifacts.
| Default: ${user.home}/.m2/repository
<localRepository>/path/to/local/repo</localRepository>
If the Job where you are building com.sac.pc:pc-salesforce:1837.02.12.xxx and running atlas-mvn eclipse:eclipse command are in different boxes, you need to make the dependency available somehow so Maven can download the dependency and use it in atlas-mvn command.
Hope the above helps.
Rafael
