We are still using maven 3.6.2 which should not require https yet.
But when do bamboo spec scan, we got error like following. The same settings.xml work for other older version bamboo
Non-resolvable parent POM for com.atlassian.bamboo:bamboo-specs-generator:1.0.0: Could not transfer artifact com.atlassian.bamboo:bamboo-specs-parent:pom:8.1.3 from/to maven-default-http-blocker (http://0.0.0.0/): Blocked mirror for repositories: [central
Hello @Yuan Xu ,
That's an expected Maven behaviour on newer releases.
Check the following links for workarounds:
When you run Maven, certain configuration files are downloaded/create. Those files have a strict HTTPS policy that needs to be modified to work with HTTP.
