Is there any way to monitor bamboo like stash or jira, ex:
Stash
wget -t 1 --connect-timeout=1 --read-timeout=3 -q -O - stash.server.ext:7990/status
JIRA
wget -t 1 --connect-timeout=1 --read-timeout=3 -q -O - jira.server.ext:8080/status
You need to enforce JSON format for the resource that @Marcin Oles mentioned. Try this call:
curl -H "Accept: application/json" $BAMBOO_URL/rest/api/latest/server
This is giving us a 401 error because of not being authenticated. (we have anonymous access disabled)
Is there a way to get Bamboo status without being authenticated and anonymous access disabled?
Hi @Fauzi Gomez,
this REST resource might be what you're looking for: <bamboo>/rest/api/latest/server
You can use it in your scripts, eg. with wget.
Marcin
Hi @Krystian Brazulewicz
Thank you, that's exactly what I wanted.
Thanks to @Marcin Oles as well.
Regards
@Marcin OleÅ›, Krystian Brazulewicz [Atlassian] how to get status of Bamboo and Crowd, like we get for JIRA and confluence - <url>/status ? if it is not there, can you please add a enhancement request or let us know any workaround for this.
we need this, we use to show status of all our Atlassian apps.
Thanks for your help.
Hi Raj,
regarding Bamboo - the way of doing so would be to use the URL we mentioned earlier:
alternatively, you may use
$BAMBOO_URL/rest/api/latest/info
To get the response in JSON format, use the command that @Krystian Brazulewicz suggested:
curl -H "Accept: application/json" <url>
You can then parse the response and retrieve server's state.
Marcin
Marcin OleÅ› [Atlassian], Thank you, yes i can get status info from that url.
but we need to login to bamboo to get this, for JIRA and Confluence, we get status without login!!
Do we have similar thing for Crowd?
Hi Raj,
unfortunately there isn't a feature like this in Bamboo yet. You may create a feature request under https://jira.atlassian.com/projects/BAM. I don't know about Crowd.
Marcin
Hi Marcin,
Is there a rest call yet to get server version, OS, Database Version, Java Version, etc.?
Hi @Marcin Oles
Thanks for the reply,
I just get a 500 Internal Server Error
My bamboo info:
Version: 5.6.2
Build: 4411
Build Date: 03 Sep 2014
for the purpose of checking if something is running on port 8085 is OK, but it is not really very useful, Any other suggestion?
Hi Himanshu,
Actually I have $BAMBOO_HOME located in a storage attached physically to two servers through SAS cables, the whole idea is to set BAMBOO in a HA environment using the STASH documentations as base.
That way I would be able to add a script to manage the service in pacemaker as an ocf:heartbeat resource.
Hi @Fauzi Gomez,
Are you using any monitoring tool like Nagios to monitor overall server resources and want to add a check to monitor overall uptime?
