I am using Bamboo 5.7.1 . When I move a plan from project X to project Y does all the build data (build number, build logs, and artifacts) move to project Y?
Hello James,
Thank you for your question.
Basically, what you will be doing is change the plan's location from one project to another and Moving a plan does not affect the plan's configuration, nor any comments or labels that have been applied to job build results within the plan. Build number, build logs and artifacts will be copied across as well.
If you find this answer useful, I would kindly ask you to accept it so the same will be visible to others who might be facing the same issue you have inquired.
Thank you for your understanding.
Rafael P. Sperafico
Atlassian Support
