×I am looking for a way to have each build run in complete isolation. I also need for each build to start with a "clean" environment. Conceptually, I want it to work like elastic bamboo with one difference... When the remote agent goes to an idle state, I want the remote VM to be destroyed not just shutdown. When a new build is queued, it should create a brand new VM for the build. This allows for build plans to install system level and/or make changes to the system configuration without the risk of impacting other builds.
We don't use EC2 but we do have a private cloud using VMWare's vCloud director. There do not appear to be any plugins currently available that work with vCloud director. I am considering writing a plugin for Bamboo that could provide this type of functionality but I think that it is going to be a fairly high level of effort (if possible at all).
I am wondering if i might be able to accomplish this using Docker. I have already tested out the docker support and 5.7 and it looks very promising. Adding the "--rm=true" parameter to the command line used to run the image causes the container to be removed when the process exits. When it is restarted, it is a brand new environment.
Unfortunately, I have not been able to come up with a way to have the remote agent exit after a build completes so that the docker container can stop running. If I could figure that part out then I could could wrap it in another script to restart it.
However, even if I solve that problem, this approach causes a new remote agent to be registered on the bamboo server every time the docker container starts. Is there a way to get around that issue?
How do I come up with a way to have the remote agent exit after a build completes so that the docker container can stop running? Adding the "--rm=true" parameter to the command line used to run the image causes the container to be removed when the process exits. When it is restarted, it is a brand new environment.
While I do not know if there will ever be a plugin in the interim there are two different things you can do. We are exploring similar options ourselves.
Both above examples will allow you to add that parameter to your docker command. You can then run whatever commands the user running the bamboo instance (or agent) thats being used can on the system.
If you choose to add the docker command as an executable you can literally add a final command task to the plan. You would choose the docker executable from the drop down (see below to get docker to appear there) and add "--rm=true" to the argument box.
Note: I recommend you add this task (command or script) as a final task. This way no matter what happens in the build pipeline, Bamboo will always execute that task and exit the docker builder and/or destroy the environment.
I honestly found a way around this by reusing the UUID when replicating agents. I suppose it would be acceptable to reuse the UUID for each project agent that lives in an environment. This is something I never really thought about. You can find this information in bamboo-agent-home/bamboo-agent.cfg.xml. The server uses this information to decide if an agent is new or not.
So far I have not had any issues reusing this UUID identifier... however someone else may feel differently about this approach. Bamboo will however reuse the name that appears in the interface for that UUID/agent relationship and change it by appending an incremented number on the end - e.g. `agent-name (n)` - for each iteration of that UUID detected.
I included steps for adding a the docker executable to your instance, these steps are pretty much copied verbatim from here https://confluence.atlassian.com/display/BAMBOO/Viewing+a+Bamboo+agent%27s+details
To define a new agent-specific executable capability:
Click Add. This will verify whether the executable and path you have specified are valid.
-- Conversely you can do the same for Bamboo itself.
To define a new local server executable capability:
A definite use of plugin would be awesome. I'm actually doing something very close to what you're doing with veewee, vagrant, puppet, etcd and unison. I however use the entirety of the inline script. We chose to use the script method, because adding a command task to plan for each required step in the docker (or in our case veewee) build process proved unwieldy. Having the steps all inline via the script task was nice and organized to look at.
I'm struggling right now with IP address handling in the environments and whether or not to use DHCP or static. I'm definitely interested if your group is using the gitflow process. If yes, how do you spin up environments in relation to your branches and repos? I have an idea of alpha, beta, and staging. Alpha would be for master branches, beta would be for release branches and staging would be for develop.
I'll probably ask that question in another thread, but if you willing to share some thoughts on your workflow I would be interested to hear them.
Good Luck
I am trying to do something similar. At the beginning of the plan I want to start a docker container (using atlassian/bamboo-java-agent:latest). The container includes the bamboo remote agent so as soon as the container is started it registers a Remote Agent with the bamboo server (agent name and container UUID is the same). I now want the rest of the build plan to execute using that specific agent and that way the code will be deployed and tested on that specific container.
We're working on a Docker plugin for Bamboo 5.8 which should help with your scenario. The plugin will provide 3 Bamboo build tasks to build, run and push Docker images. The Docker run task will run with the --rm=true parameter by default but you can also optionally run the container detached (--detach) and Bamboo will remove the detached containers at the end of the job even if the container is still running.
These tasks run on existing agents with the Docker capability (not inside a Docker Bamboo agent) so there's no need to terminate the remote agent.
