×I have added a "after successful build plan" trigger to a deployment plan, but it does not seem to be working.
The wording states the following...
When a deployment is automatically triggered, a new release is created from the latest successful build result of the linked plan.
However, this does not seem to be the case, as 15 minutes after a successful build, no release has been created, and thus nothing has been deployed.
The build plan has only one stage, and all jobs completed successfully; the build is not waiting for manual intervention.
I'm running Bamboo version 6.9.1.
David
Hi @David Gard
According to your description, the build deployment should be triggered after the build.
Would you mind double-checking the plan and selected branch by going to Deployment configuration >> Edit build plan >> Linked build?
Other checks to help troubleshooting this:
I hope the above will helps us to narrow down what is causing this issue.
Thanks for your reply,
With regards to the build plan - yes, the correct plan is linked. I can manually create a release and deploy it.
In answer to your other questions -
Hi @David Gard
Things I would try to move forward:
Please let me know your thoughts and comments.
