Welcome to the next Bitbucket Pipes digest. This month comes packed with additions to Pipes. Don’t forget to subscribe (click Watch and select Articles)!
atlassian/bitbucket-chatgpt-codereview:0.1.2 Unlock AI's power of ChatGPT for code review of pull requests |
pipelines: pull-requests: '**': - step: name: Build for any pull request created script: - pipe: atlassian/bitbucket-chatgpt-codereview:0.1.1 variables: OPENAI_API_KEY: $OPENAI_API_KEY BITBUCKET_ACCESS_TOKEN: $BITBUCKET_ACCESS_TOKEN MODEL: 'gpt-4-turbo-preview' default: - step: name: All other builds script: - echo "Default build"
atlassian/bitbucket-iac-scan:0.2.0 Perform IaCSS with KICS. IaCSS examines configuration definitions and scripts used to instantiate infrastructure to ensure the resulting resources are secure. |
script: - pipe: atlassian/bitbucket-iac-scan:0.2.0 variables: FILES_TO_SCAN_PATH: ./my_files_to_scan
atlassian/crate-ci-typos-check:1.2.3 Source code spell checker |
script: - pipe: atlassian/crate-ci-typos-check:1.2.3
atlassian/poetry-cli-setup:0.2.0 Setup Poetry CLI in Bitbucket Pipelines |
script: - pipe: atlassian/poetry-cli-setup:0.2.0 - ./setup-poetry.sh - poetry install - poetry run pytest
cqse/teamscale-bitbucket-pipeline:1.0.2 A Bitbucket pipe for uploading external reports to Teamscale |
pipelines: branches: master: - step: name: create code coverage script: # Create your reports here - ./run-coverage.sh artifacts: # Store reports for usage in upload step paths: - coverage-reports/cobertura.xml - step: name: upload reports to Teamscale script: - pipe: cqse/teamscale-bitbucket-pipeline:1.0.2 variables: SERVER: ${TEAMSCALE_SERVER} PROJECT: ${TEAMSCALE_PROJECT} USER: ${TEAMSCALE_USER} ACCESSKEY: ${TEAMSCALE_ACCESS_KEY} PARTITION: 'bitbucket-reports' INPUT: '.teamscale-reports'
launchdarkly/ld-find-code-refs-pipe:2.12.0 Job for finding and sending feature flag code references to LaunchDarkly
atlassian/azure-storage-deploy:2.2.0 Deploy files and directories to Azure Storage
atlassian/aws-lambda-deploy:1.11.1 Deploy function to AWS Lambda
atlassian/azure-aks-helm-deploy:3.3.0 Deploy to AKS (Azure Kubernetes Service) using Helm
atlassian/azure-aks-deploy:1.3.0 Deploy to AKS (Azure Kubernetes Service) using Kubectl
This pipe uses Snyk to find, fix and monitor known vulnerabilities in your app dependencies and docker image
atlassian/google-cloud-storage-deploy:2.0.0 Deploy code to Google Cloud Storage
atlassian/aws-eks-kubectl-run:2.8.0 Execute a kubectl command on your Amazon EKS (Elastic Kubernetes Service) cluster.
scribe-security/valint-pipe:1.1.0 Generate Software Bill Of Materials (SBOM) for container images, filesystems and git repositories
Send a notification to email.
atlassian/aws-cloudformation-deploy:0.20.0 Deploy your stack configuration template to AWS CloudFormation
Deploy to Amazon S3.
atlassian/firebase-deploy:5.1.0 Deploy your code to Firebase using this pipe.
atlassian/jira-create-issue:0.7.0 With this pipe you can create a JIRA issue from a Bitbucket Pipeline
This is a pipe to perform scan by Renovate
configcat/scan-repository-pipe:1.4.4 Find code references to ConfigCat feature flags and settings in your source code.
To discover more pipes, visit our Bitbucket Pipes Marketplace.
If you’d like to suggest a pipe to be improved or new pipe to be implemented, please, find the appropriate ticket in the list of existing tickets , vote for them or create a new suggestion request with type Suggestion and Component: Pipelines - Pipes.
If you’d like help with Bitbucket Pipes, or you have an issue or feature request, let us know on Community.
Oleksandr Kyrdan
0 comments
