Sign up Log in
What to do with your Mercurial repos when Bitbucket sunsets support
531 comments
Alex Bream
But everybody can continue to use THG with hg-git for Git-repos anyway
ulfkri
September 22, 2019
Really? You are deleting our repositories?
One thing is to discontinue support for Mercurial. That's your decision, many people will wish you hadn't but that's fine.
But deleting our repositories? That is something completely different.
You are a source control provider. We come to you and trust you not to... delete our code. As a source control provider the very least you can provide is... not delete our code. And then you... delete it?
How on earth do you expect users to trust you after this?
Like # people like this
Deleted user September 23, 2019
It's been a pain moving all my repos across, but I decided on converting to git, and migrating to GitLab in the end. I'll eventually wind down my bitbucket repos and say "goodbye, 'twas nice using your service at one point".
I generally have prefered hg to git, at least in terms of hg as a more focused vcs with fewer crazy options... but one really annoying thing about hg is the weird multiple branch heads thing. (Shame bazaar never took off that much, as it seemed even more intuitive.)
Vadym Kurachevskyi
September 25, 2019
Make it possible to just to convert the repositories.
It would be much better if you guys propose a migration tool.
laice_
September 25, 2019
Google Code offered a migration tool to your service when they sunsetted. You should provide a conversion tool. This is pretty half-assed on your part otherwise
sirgazil
With Halloween approaching, Bitbucket product marketing team is discussing a "topic tailor-made for October": Share your software development horror stories!
Maybe the Bitbucket Hg Repo Massacre would qualify?
rmills
September 26, 2019
I've been a Bitbucket user since 2012. I'd be happy to stay a Bitbucket user, but if they are just going to delete all of my Mercurial repos, and aren't providing an easy way to migrate them to git automatically, I can't see any reason why I should keep using Bitbucket. If they are going to force me to go to a bunch of pain by hand, I don't see why I wouldn't just move everything to Github or Gitlab, where I'm more confident that they won't decide to just blow away a bunch of my repositories. Is anyone from Bitbucket listening? Seems like they aren't, since every major project I've worked on seems to have abandoned Bitbucket in favor of Github or Gitlab due to the general unreliability of service.
ekolis
Maybe this is all part of the plan - purge a bunch of repos and only the paying customers will bother to stay?
herman_schmit
September 28, 2019
And I'm done in 15 minutes!
Moved everything to GitHub. Really quite easy. Goodbye bitbucket, no thanks to Atlassian.
maghoff
October 1, 2019
I ended up making a script to migrate all repos (hg or git) from Bitbucket to git and GitHub. Its most severe limitation is that it won't migrate issues, but perhaps somebody else can add that?
See https://magnushoff.com/blog/kick-the-bitbucket/ and https://twitter.com/magistratic/status/1178679193606987778 :)
svtrijp
October 1, 2019
Can we get some support in migrating 50+ repositories?
I'm familiar with bash scripting and GIT, but I'm stuck on 2 things:
- getting a list of all Mercurial repositories in the team from the command line
- creating a new team GIT repository from the command line
We tried to work with the API but run into issues with authentication and CSRF. A command line interface (like the old Python bitbucket-cli) should be a great solution!
Hope we can get some help on this.
Best regards,
Sven.
MartinHvidberg
October 13, 2019
Goodby BitBucket, and thanks for all the fish ...
Like kuchura likes this
punytroll
October 16, 2019
Git is the industry standard for version control systems?
Yeah, well, so is GitHub for git repository hosting!
Bye, Bitbucket!
kalthad
Out of curiosity, I created a git repository, used the hg-git plugin and tried to push
and obtained
abort: git remote error: unexpected http resp 401 for https://kalthad@bitbucket.org/kalthad/euler-nordstrom-git.git/info/refs?service=git-receive-pack
great.
Like sclinch likes this
John Arrizza
October 16, 2019
I found a python based bitbucket interface on the net. Unfortunately it is out of date wrt to the REST API v2.
The original is here: https://pypi.org/project/bitbucket-cli/
and here is my clone of it: https://bitbucket.org/arrizza/bitbucket-cli/src/master/
I have been able to modify the "bitbucket list" command to use Rest API v2 and it works! (On ubuntu only I have not tried it on Mac or Windows).
It's working. Full instructions are in the README, see section
How to convert Mercurial Repos to Git
I have converted about 10 hg repos with no problems so far.
Like clach04 likes this
Ruslan Berezyuk
Ok, since this looks to be irreversible and there looks to be null support from BitBucket, we slowly started migrating our existing repos to Helix TeamHub. (we have 100+ of them)
The product is not very good promoted, but I was using it for a couple of weeks on one project and I would say I definitely like it! Here is a short review:
Pros
  • Support several version systems, including mercurial, git, subversion and few more I never heard about!
  • Free for 5 users. For 5+ it costs $19/year! (less expensive then BitBucket)
  • Allows to group Repositories in projects. Each project has it's own Wiki and Issue tracker
  • Pull request and code review very similar to BitBucket experience
  • Support integration with a ton of external services, including Jira, Slack, Trello, etc
Cons
  • No download section (useful for upload binaries). A workaround is to have a dedicated  Wiki page and submit binaries as attachment
  • You can't move repositories between projects
  • No public repositories (not suitable for Open Source)
An interesting fact is that TeamHib was lunched in 2017! It looks like it gets updated a couple of times a year. This sounds like an irony, while ones are dropping support for "unpopular mercurial", others lunch new products based on it and making a business.
Bradbury Hart
October 19, 2019
Thanks for your comment Ruslan!
Just as an FYI, we (the Perforce Helix TeamHub team) are in the process of adding code search support for Mercurial and will then be adding the ability to make code edits as well as create branches directly from the web browser like we currently support for Git. Mercurial is a first class citizen with Helix TeamHub!
 -Brad
CTO Perforce
-tukanos-
@Bradbury Hart  is Helix planning to add a possibility for public repositories?  I would be interested in a mix of closed & public ones.
Alex Bream
@Bradbury Hart - I suppose (follow-up to tukanos), public repos have to be a must for Helix Hub in order to consider it as common-case replacement of BB.
And, please, don't ignore fresh and usable addition to Mercurial - add server-side support of evolve in your HG (it's sometimes more important, than bells&whistles in webUI), just because nobody still offer it as public feature and it's really must-have thing
Like -tukanos- likes this
Bradbury Hart
October 21, 2019
@Ruslan Berezyuk  @-tukanos-  @Alex Bream
Thanks for the feedback. That is always very helpful and welcome. Brent Schiestl ( bschiestl@perforce.com ) is the Product Manager that owns Helix TeamHub. Please feel free to reach out to him and he can share where we are going with the product and talk further with you to understand you use cases around the features you are requesting.
Thanks again!
 -Brad
Deleted user October 27, 2019
Congrats, Atlassian, you are now a prime example for all those that don't put a single trust into cloud companies, especially if their PR agents keep on writing text like "Mercurial will always have a special place in Bitbucket's history".
Not only do you want to delete repos instead of putting them on a read-only back-burner, like decent companies that went out of this business did in the past. No, you don't even help your former users with this painful migration. I am pretty sure you will do so with Git repos as well one day.
Just in case you don't know so already, this sends a clear message: never, ever trust Atlassian with your code.
Edgard Schmidt
October 29, 2019
@philipstarkey @maghoff
You might be interested in rerefcommit, which allows you to translate commit references from hg to git. The Example section of the README shows you how to do this with Bitbucket issue dumps.
However, note the described limitations of that example. To convert bigger repositories, a dedicated Bitbucket conversion tool which makes use of the general-purpose rerefcommit library should provide better results. But I'm not interested in writing such a tool.
Update 2020/01/03: the JSON translation functionality, which can be used for the translation of the issue dumps, has moved to rerefcommitjson.
Like sreedevin likes this
edrandall November 2, 2019
I have written a conversion tool and made it available HERE,
Feedback is welcome, I hope you find it useful.
kalthad
very intesting, a couple of questions:
  1. are named branches supported?
  2. It is supposed to be converted to git and then git should be used? What's about sticking with Mercurial and using hg-git plugin
  3. I did manually a different thing, I generated a git repository, used the latest hg-git plugin + a patch which makes the treatment of named branches easier (topics are not supported). Then I pushed and run some test with other mercurial users, using the same configuration and it worked well.
so the question is could you tool also be used for the conversion, but sticking with mercurial and the hg-git plugin.
thanks
Uwe Brauer
edrandall November 3, 2019
Hi Uwe,
I've added a Wiki page to the project with an FAQ  which I hope answers your questions.
Basically my tool is completely non-destructive, it creates a new `-git` clone of your repository, so you can try it out and use whatever tools you like afterwards.
Regards, Ed.
