×I needed to add:
to /var/atlassian/application-data/bitbucket/shared/bitbucket.properties.
Hi Filipe! That is likely to be a proxy misconfiguration. Please revise your Nginx configuration against the document Securing Bitbucket Server behind Nginx using SSL.
Let us know if you have any questions!
Regards!
Ana
Thank you very much but the problem was not Nginx configuration. itself.
