If the S3 bucket does not exist when the pipe is run, but the identity the pipe is operating under has rights to create a bucket, the pipe should create the bucket assuming there are no name conflicts.
This would increase the ease of use of the pipeline and make it easier to implement.
Hi @Nick Reilingh . Thank you for this feedback, we'll consider adding such behavior to the pipe.
From setup to deployment—this learning path shows you how to build your first app using Forge. Learn the essentials, streamline workflows, and bring custom solutions to life across Jira, Confluence, and more.
Start Learning
