Hi, I am solving problem with starting Bitbucket.
I have configured bitbucket.properties like this (default setup didn't work for me also):
#> Migrated to database at jdbc:postgresql://psql-bitbucket.*******.eu-central-1.rds.amazonaws.com:****/psql_bitbucket_live
#> Updated on 2018-09-07T15:21:55.441+02:00
jdbc.driver=org.postgresql.Driver
jdbc.url=jdbc:postgresql://psql-bitbucket.c1111111gguo.eu-central-1.rds.amazonaws.com:5555/psql_bitbucket_live
jdbc.user=bitbucketuser
jdbc.password=my-secret-passwd
server.scheme=https
server.ssl.key-store-type=jks
server.port=8443
server.ssl.enabled=true
server.ssl.key-store=/var/atlassian/application-data/bitbucket/shared/config/ssl-keystore.jks
server.ssl.key-alias=tomcat
server.ssl.key-store-password=my-secret-passwd
server.ssl.key-password=my-secret-passwd
keystorePass=my-secret-passwd
I also checked my keystore as is it recommended here.
This is my key:
$ keytool -list -v -keystore ssl-keystore.jks -alias tomcat
Enter keystore password:
Alias name: tomcat
Creation date: Sep 14, 2018
Entry type: trustedCertEntry
But Bitbucket still can't start and returns Alias name [tomcat] does not identify a key entry.
Here is beginning of the log when I try to start Bitbucket:
2018-09-17 12:30:28,717 INFO [main] c.a.b.i.b.BitbucketServerApplication Starting BitbucketServerApplication on mbczvl6al0bibl1.ux.mbid.cz with PID 5451 (/aplikace/bitbucket/app/WEB-INF/classes started by atlbitbucket in /)
2018-09-17 12:30:28,717 INFO [main] c.a.b.i.b.BitbucketServerApplication No active profile set, falling back to default profiles: default
2018-09-17 12:30:29,705 INFO [main] c.a.b.i.boot.log.BuildInfoLogger Starting Bitbucket 5.13.1 (2c2ed6e built on Tue Aug 21 07:11:42 CEST 2018)
2018-09-17 12:30:29,705 INFO [main] c.a.b.i.boot.log.BuildInfoLogger JVM: Oracle Corporation Java HotSpot(TM) 64-Bit Server VM 1.8.0_181
2018-09-17 12:30:31,357 ERROR [main] o.a.catalina.core.StandardService Failed to start connector [Connector[HTTP/1.1-8443]]
org.apache.catalina.LifecycleException: Failed to start component [Connector[HTTP/1.1-8443]]
at org.apache.catalina.util.LifecycleBase.start(LifecycleBase.java:167)
at org.springframework.boot.context.embedded.tomcat.TomcatEmbeddedServletContainer.addPreviouslyRemovedConnectors(TomcatEmbeddedServletContainer.java:265)
at org.springframework.boot.context.embedded.tomcat.TomcatEmbeddedServletContainer.start(TomcatEmbeddedServletContainer.java:208)
at org.springframework.boot.context.embedded.EmbeddedWebApplicationContext.startEmbeddedServletContainer(EmbeddedWebApplicationContext.java:297)
at org.springframework.boot.context.embedded.EmbeddedWebApplicationContext.finishRefresh(EmbeddedWebApplicationContext.java:145)
at org.springframework.context.support.AbstractApplicationContext.refresh(AbstractApplicationContext.java:546)
at org.springframework.boot.context.embedded.EmbeddedWebApplicationContext.refresh(EmbeddedWebApplicationContext.java:122)
at org.springframework.boot.SpringApplication.refresh(SpringApplication.java:693)
at org.springframework.boot.SpringApplication.refreshContext(SpringApplication.java:360)
at org.springframework.boot.SpringApplication.run(SpringApplication.java:303)
at com.atlassian.bitbucket.internal.boot.BitbucketServerApplication.start(BitbucketServerApplication.java:246)
at com.atlassian.bitbucket.internal.boot.BitbucketServerApplication.main(BitbucketServerApplication.java:82)
at org.springframework.boot.loader.MainMethodRunner.run(MainMethodRunner.java:48)
at org.springframework.boot.loader.Launcher.launch(Launcher.java:87)
at com.atlassian.bitbucket.internal.launcher.BitbucketServerLauncher.start(BitbucketServerLauncher.java:151)
at com.atlassian.bitbucket.internal.launcher.BitbucketServerLauncher.main(BitbucketServerLauncher.java:99)
... 5 frames trimmed
Caused by: org.apache.catalina.LifecycleException: Protocol handler start failed
at org.apache.catalina.connector.Connector.startInternal(Connector.java:1020)
... 16 common frames omitted
Caused by: java.lang.IllegalArgumentException: Alias name [tomcat] does not identify a key entry
at org.apache.tomcat.util.net.AbstractJsseEndpoint.createSSLContext(AbstractJsseEndpoint.java:116)
Caused by: java.io.IOException: Alias name [tomcat] does not identify a key entry
at org.apache.tomcat.util.net.jsse.JSSEUtil.getKeyManagers(JSSEUtil.java:229)
2018-09-17 12:30:34,169 WARN [spring-startup] c.a.stash.internal.home.HomeLock Failed to write process information into the lock file
java.nio.channels.ClosedByInterruptException: null
at java.nio.channels.spi.AbstractInterruptibleChannel.end(AbstractInterruptibleChannel.java:202)
at sun.nio.ch.FileChannelImpl.write(FileChannelImpl.java:216)
at com.atlassian.stash.internal.home.HomeLock.acquireLock(HomeLock.java:127)
at com.atlassian.stash.internal.home.HomeLock.lock(HomeLock.java:98)
at com.atlassian.stash.internal.home.HomeLockAcquirer.lock(HomeLockAcquirer.java:58)
at org.springframework.context.support.PostProcessorRegistrationDelegate.invokeBeanFactoryPostProcessors(PostProcessorRegistrationDelegate.java:151)
at org.springframework.context.support.AbstractApplicationContext.invokeBeanFactoryPostProcessors(AbstractApplicationContext.java:687)
at org.springframework.context.support.AbstractApplicationContext.refresh(AbstractApplicationContext.java:525)
Rights for mentioned files are set this way: -rw-r----- 1 atlbitbucket atlbitbucket
Can anyone help me please?
Does anoyone has an idea where could be the problem?
Thank you for every recommendation.
same here, did you find the solution for this problem ?
tks
tks
