×I have Bamboo setup now to build our entire source tree. (Daily Build). I made a change to a file on my Dev machine, and checked it in. I then went to the build server and kicked off a build.
Under the "Code Changes" section it shows the checkin, however the file I changed DID NOT get updated. I have no explanation for this, but it worries me. I've tried to force a build several times since then and it does not update that file.
We use Subversion to store our code.
Has anybody seen this? Is there a setting somewhere I need to change? I'm a little worried about this, if we can't count on Bamboo to sync our tree properly.
Jim
I think I made a mistake. I had also disabled one task and enabled another. I didn't realize that it used a separate build-tree for that. I was looking in the disabled build's tree, which wasn't being updated.
I think Bamboo was working correctly. (whew).
