Hi.
When I try to execute the created plan on bamboo, the system show me a access denied error, even the integration correctly configured.
com.atlassian.bamboo.repository.RepositoryException: java.lang.RuntimeException: com.atlassian.bamboo.repository.RepositoryException: java.lang.RuntimeException: java.io.IOException: Acesso negado at com.atlassian.bamboo.v2.trigger.DefaultChangeDetectionManager.collectChangesSinceLastBuildInternal(DefaultChangeDetectionManager.java:371) at com.atlassian.bamboo.v2.trigger.DefaultChangeDetectionManager.collectChangesSinceRevisions(DefaultChangeDetectionManager.java:259) at com.atlassian.bamboo.v2.trigger.DefaultChangeDetectionManager.collectChangesSinceRevisions(DefaultChangeDetectionManager.java:161) at com.atlassian.bamboo.v2.trigger.DefaultChangeDetectionManager.collectAllChangesSinceLastBuild(DefaultChangeDetectionManager.java:127) at com.atlassian.bamboo.v2.trigger.ManualBuildDetectionAction.performDelayedChangeDetection(ManualBuildDetectionAction.java:173) at com.atlassian.bamboo.chains.ChainExecutionManagerImpl$2.getChainState(ChainExecutionManagerImpl.java:209) at com.atlassian.bamboo.chains.ChainExecutionManagerImpl.tryStartChainState(ChainExecutionManagerImpl.java:262) at com.atlassian.bamboo.chains.ChainExecutionManagerImpl.delayedStart(ChainExecutionManagerImpl.java:198) at sun.reflect.GeneratedMethodAccessor1649.invoke(Unknown Source) at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43) at java.lang.reflect.Method.invoke(Method.java:606) at org.springframework.aop.support.AopUtils.invokeJoinpointUsingReflection(AopUtils.java:304) at org.springframework.aop.framework.ReflectiveMethodInvocation.invokeJoinpoint(ReflectiveMethodInvocation.java:182) at org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:149) at org.springframework.aop.interceptor.ExposeInvocationInterceptor.invoke(ExposeInvocationInterceptor.java:89) at org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:171) at org.springframework.aop.framework.JdkDynamicAopProxy.invoke(JdkDynamicAopProxy.java:204) at com.sun.proxy.$Proxy99.delayedStart(Unknown Source) at com.atlassian.bamboo.plan.PlanExecutionManagerImpl$1$1$1.call(PlanExecutionManagerImpl.java:383) at com.atlassian.bamboo.plan.PlanExecutionManagerImpl$1$1$1.call(PlanExecutionManagerImpl.java:378) at com.atlassian.util.concurrent.ManagedLocks$ManagedLockImpl.withLock(ManagedLocks.java:312) at com.atlassian.bamboo.plan.PlanExecutionLockServiceImpl.lock(PlanExecutionLockServiceImpl.java:81) at com.atlassian.bamboo.plan.PlanExecutionManagerImpl.doWithProcessLock(PlanExecutionManagerImpl.java:725) at com.atlassian.bamboo.plan.PlanExecutionManagerImpl.access$200(PlanExecutionManagerImpl.java:123) at com.atlassian.bamboo.plan.PlanExecutionManagerImpl$1$1.run(PlanExecutionManagerImpl.java:377) at com.atlassian.bamboo.build.pipeline.concurrent.NamedThreadFactory$2.run(NamedThreadFactory.java:55) at java.lang.Thread.run(Thread.java:744) Caused by: java.lang.RuntimeException: com.atlassian.bamboo.repository.RepositoryException: java.lang.RuntimeException: java.io.IOException: Acesso negado at com.atlassian.bamboo.executor.RetryingTaskExecutor.rerun(RetryingTaskExecutor.java:132) at com.atlassian.bamboo.executor.RetryingTaskExecutor.runTask(RetryingTaskExecutor.java:88) at com.atlassian.bamboo.executor.RetryingTaskExecutor.retry(RetryingTaskExecutor.java:191) at com.atlassian.bamboo.executor.RetryingTaskExecutor.retry(RetryingTaskExecutor.java:176) at com.atlassian.bamboo.v2.trigger.DefaultChangeDetectionManager.collectionChangesWithRetry(DefaultChangeDetectionManager.java:474) at com.atlassian.bamboo.v2.trigger.DefaultChangeDetectionManager.collectChangesSinceLastBuildInternal(DefaultChangeDetectionManager.java:331) ... 26 more Caused by: com.atlassian.bamboo.repository.RepositoryException: java.lang.RuntimeException: java.io.IOException: Acesso negado at com.atlassian.bamboo.plugins.git.GitRepository.collectChangesSinceLastBuild(GitRepository.java:304) at com.atlassian.bamboo.plugins.git.GitRepository.collectChangesSinceLastBuild(GitRepository.java:205) at com.atlassian.bamboo.v2.trigger.DefaultChangeDetectionManager$1.call(DefaultChangeDetectionManager.java:479) at com.atlassian.bamboo.v2.trigger.DefaultChangeDetectionManager$1.call(DefaultChangeDetectionManager.java:475) at com.atlassian.bamboo.executor.RetryingTaskExecutor.rerun(RetryingTaskExecutor.java:108) ... 31 more Caused by: com.google.common.util.concurrent.UncheckedExecutionException: java.lang.RuntimeException: java.io.IOException: Acesso negado at com.google.common.cache.CustomConcurrentHashMap$ComputedUncheckedException.get(CustomConcurrentHashMap.java:3305) at com.google.common.cache.CustomConcurrentHashMap$ComputingValueReference.compute(CustomConcurrentHashMap.java:3441) at com.google.common.cache.CustomConcurrentHashMap$Segment.compute(CustomConcurrentHashMap.java:2322) at com.google.common.cache.CustomConcurrentHashMap$Segment.getOrCompute(CustomConcurrentHashMap.java:2291) at com.google.common.cache.CustomConcurrentHashMap.getOrCompute(CustomConcurrentHashMap.java:3802) at com.google.common.cache.ComputingCache.get(ComputingCache.java:46) at com.atlassian.bamboo.plugins.git.GitCommandProcessor.checkGitExistenceInSystem(GitCommandProcessor.java:201) at com.atlassian.bamboo.plugins.git.NativeGitOperationHelper.<init>(NativeGitOperationHelper.java:82) at com.atlassian.bamboo.plugins.git.GitOperationHelperFactory.createGitOperationHelper(GitOperationHelperFactory.java:25) at com.atlassian.bamboo.plugins.git.GitRepository.collectChangesSinceLastBuild(GitRepository.java:215) ... 35 more Caused by: java.lang.RuntimeException: java.io.IOException: Acesso negado at com.atlassian.bamboo.plugins.git.GitCommandProcessor.getSshScriptToRun(GitCommandProcessor.java:122) at com.atlassian.bamboo.plugins.git.GitCommandProcessor.createCommandBuilder(GitCommandProcessor.java:442) at com.atlassian.bamboo.plugins.git.GitCommandProcessor$1.load(GitCommandProcessor.java:172) at com.atlassian.bamboo.plugins.git.GitCommandProcessor$1.load(GitCommandProcessor.java:166) at com.google.common.cache.CustomConcurrentHashMap$ComputingValueReference.compute(CustomConcurrentHashMap.java:3426) ... 43 more Caused by: java.io.IOException: Acesso negado at java.io.WinNTFileSystem.createFileExclusively(Native Method) at java.io.File.createNewFile(File.java:1006) at com.atlassian.bamboo.util.BambooFileUtils.createSafeTempFile(BambooFileUtils.java:338) at com.atlassian.bamboo.util.SharedTemporaryFiles.createTempFile(SharedTemporaryFiles.java:43) at com.atlassian.bamboo.util.SharedTemporaryFiles.access$000(SharedTemporaryFiles.java:18) at com.atlassian.bamboo.util.SharedTemporaryFiles$1.load(SharedTemporaryFiles.java:31) at com.atlassian.bamboo.util.SharedTemporaryFiles$1.load(SharedTemporaryFiles.java:27) at com.google.common.cache.CustomConcurrentHashMap$ComputingValueReference.compute(CustomConcurrentHashMap.java:3426) at com.google.common.cache.CustomConcurrentHashMap$Segment.compute(CustomConcurrentHashMap.java:2322) at com.google.common.cache.CustomConcurrentHashMap$Segment.getOrCompute(CustomConcurrentHashMap.java:2291) at com.google.common.cache.CustomConcurrentHashMap.getOrCompute(CustomConcurrentHashMap.java:3802) at com.google.common.cache.ComputingCache.get(ComputingCache.java:46) at com.atlassian.bamboo.util.SharedTemporaryFiles.getFile(SharedTemporaryFiles.java:98) at com.atlassian.bamboo.util.BambooFileUtils.getSharedTemporaryFile(BambooFileUtils.java:623) at com.atlassian.bamboo.plugins.git.GitCommandProcessor.getSshScriptToRun(GitCommandProcessor.java:117) ... 47 more
Additional information:
* bamboo version 5.3, integrated with Jira 6.5 and stash 2.10
* the plan is git repository / stash.
What can generate this problem?
If anyone have any idea about the solution or knowledge the cause of this problem I’ll be gratefully.
Thanks all.
Hi I have changed the two things and resolved the issue:
1. changed user permissions at the file write path of Bamboo
2. unchecked Enable restricted administrator role in the security options at Bamboo
Hi Ricardo,
Could is be that your git repository isn't publicly accessible and you haven't configured a user for it in your Bamboo Build plan? So if Bamboo wants to checkout the repo it will get an access denied error.
Best regards,
Peter
This is the Project's settings from Stash. You can see the admin is set with Read and Write permissions. This is the same user from Bamboo.
Can you create a directory, say c:\tmp and run Bamboo with
-Djava.io.tmpdir=c:/tmp
Can you point where this parameter could be set? I've tried looking for it on the .bat files but didn't find any clue where to change. Can you be more specific?
Hi Mirko.
Well, the stash and bamboo user are the same and has admin privileges.
I thought of that too but I don't know where I can change/add any permission that might be missing with jira, stash and bamboo communication.
At the application links settings I've setup the basic authentication, is there any other way to set it up?
Also, at bamboo shows a message: "Did not start" Looks like it's not starting the plan.
I feel like we mix up multiple permission problems. One is the user at operating system level, the user which starts the tomcat. The other is the user within the application (bamboo). These are two different user spaces and they have nothing to do with each other. I also think it has nothing to do with the integration (jira or stash).
Can you check the directory and file permissions on the home directory?
Hi, Mirko.
Right. Well, I checked the permissions and my user (which runs tomcat) is the computer's admin so I have permission on all folders of the operating system.
Could the problem be related with JIRA/STASH/BABOO running on the same computer?
jira: localhost:8080
stash: localhost:7990/stash
bamboo: localhost:8085/bamboo
Thank you!
Hi Ricardo, I don't think it's a problem running Jira, Stash and Bamboo on the same machine. Have you tried Przemeks suggest?
No, I didn't had time to try yet. I'll post the results here as soon as I try.
Thanks for the help so far!
Hi Ricardo,
seems like a problem accessing the filesystem. Can you check if the bamboo-user can read and write from/to its home directory?
Best regards, Mirko
